I am in the process of modifying my r33 gtst, but would like to keep it as stock looking under the engine bay as possible.
I am running a GT30, and have read that aftermarket boost controllers are not legal in VIC, but i would like more boost than the stock 9psi. Therefore I have started looking into how the factory one works. From what I can tell, and I may be wrong here, is works like this:
Boost pressure from intake pipe goes through a rubber hose with a sort of calibrated restrictor in it, and then to the wategate actuator.
The solenoid bleeds air from this hose via the t-piece, and routes the air back into the intake, thus controlling the boost by how much air is bled off.
As far as I know the ECU doesnt know how much boost there actually is (in psi).
So heres my theory:
If you get rid of the hose from the intake pipe to the t-piece, and replace it with a hose that has a pice of brass in it with a hole drilled through (to a specific size), and by controlling the size of that hole, the boost could be increased while still looking like its stock.
I hope that made sense!
Does anyone know if the factory solenoid has only the 2 specific bleed rates (7 + 9psi) or can it vary?
Im not sure what size hole would have to be drilled in the restrictor because i threw out my factory hoses in favour of one of those $22 dollar boost controllers.
https://www.sau.com.au/forums/topic/196534-modifying-stock-boost-solenoid/
isn't it illegal to whack a after market turbo on to??? why worry about the boost controller....
But yeah stock boost solenoid just opens and bleeds air from the actuator at a set RPM by the ecu (5000 RPM or something)
I think what you said is feasible.
what you could possibly do is use a t-piece in place of the solenoid and play around with the size of the hole (fill 1 hole on tee piece with solder and use drill to adjust hole size) on the bleed part of the tee then just plug it back into the stock location when done if that makes any sense. (sounds dodgey hey)
Just throwing ideas your way.
Yes you can bleed off the air like that. Theres a tube with a restrictor in it already somewhere - i believe it has a yellow dot on it to identify. Change the size of the restrictor or even just prick small holes in it with a hot needle until you achieve your required boost.
you can also cut the solenoid arm in half, thread it, add a threaded sleeve to rejoin it, hence giving you full adjustment
you can use the stiffer spring from an r32 and run the slightly higher boost
remove the spring, drill a hole in the top and weld a nut to it, insert a bolt and fit a spring seat to the otherside. This will allow you to adjust spring pre-tension, thus giving you full adjustment
All these retain the factory setup
i know what he's talking about.
jetting it down to trick the stock solenoid = more boost. not very good on skylines bro as they spike quite badly
get yourself a good ebc and be done with it... afterall you got a gt30 lol
good luck
Mate if you have hidden the GT30 then you can hide the boost controller, at least from the cops.
But if you get sent to the EPA @ Mcleod your stuffed, those blokes know their stuff. They will surely find a GT30!
Personally I would use a modified or adjustable wastegate actuator for "stealth" boost control.
Good luck!
Cheers guys, some really good options in that lot :D
Your right with the GT30, bit hard to hide, but ive still got it std position and done the job on the stock cover to make it fit and look roughly like standard. You can tell when you look at it from the front and theses a 4" pipe coming off it that it shouldnt be there.
I did have a play around with the wastegate actuators, and eneded up with one off some really small garret I had laying around. With the hose going straight from the manifold to the turbo actuator, it holds 7psi to about 4500, then goes to 10 - 11 psi up to the redline.
This is all the boost it can handle at the moment, as the stock injectors hit 80% at 6250. So I think i will try out one of the restrictor/hole in the hose ideas as posted above when i fit bigger injectors and are looking for a few psi more boost.
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
