r32 actulator = $40
2 x Nissan Stega Rims = $70 no tyres or $120 with
2 x Borbet rims 5 x 114.3 17" = $70
Blown r32 turbo needs seals = $30
r32 roof linning sunroof coupe $20
These parts have been removed from a r33 gtst coupe
R33 complete fuel pump setup up = $80
Fuel Cap = $15
Clutch Fan = $40
Manual Tailshaft = $100
Fibreglass Rear Wing = $80
Veilside Rear Pods original with stamps= $200
Indicator Stalk = $50
Handbrake Lever = $25
r33 diff = $200
Complete rear driveline with diff brakes cradle axles the lot = $500
Passenger seat series 1 = $70
Back interior side panels $40 pair
Rear rio bar = $40
Rear seat complete $50
front cross member = $40
front hubs = $80 pair
floor carpet = $40
Hicas 4WS unit rear = $70
fuel lid = $10
r33 brake cyclinder = $60
r33 x 2 doors = $70 each with glass
r33 condenser = $70
r33 gtst rims = $200
r33 corner windows = $35 each
r33 rear glass = $50
r33 mirrors l and r = $80 pair
contact me via mob on 0402090079 or pm me
all prices are negotiable and offers will be considered
items located in keilor western subs of Melbourne everything to be sold
Edited by SXC_R33
This smells far too fishy to me.
Both threads are locked.
If there are 3 separate people who don't know each other, and all giving the same story out.
I'm inclined to believe them in this instance.
Selling goods from stolen cars will not be tolerated on SAU regardless of if "i purchases it legally".
I simply dont give a shit for dodgy reasons
Cheers.
http://www.skylinesaustralia.com/forums/So...ys-t184498.html
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
