Hello everyone I no longer have time for cars anymore.
SELLING:
DR30
FRONT STRUTS x2, brakes, King Springs, Noltech bushed control arms, also have original DR30 springs and electric spring heighten'er thingos, strong shocks, frontal Whiteline swaybar incl.
REAR STRUTS x2, whole crossmember, assembled with R30 rear swaybar, DR30 Brakes, noltech swaybar bushing, King Springs, ok shocks.
$550 for everything above. ono
All of the re bushing done has cost me an odd $230 alone and was done with Noltech bushes (Have receipts) I know I'm not getting that back but realise it's mention might be respected in the buy.
General R30 gear that is half mentioned/not mentioned:
Front and rear Whiteline Swaybars, never been used! ~(both come with front and rear strut packages)~
Solid MR30 gearbox $50
MR30 brake booster/master cyl 3/4" clean and good condition $ 10
MR30 TI ALLOYS, 7, 2 with good matching tires, 16 wheelnuts, $200 ono.
Good clean MR30 Radiator $20
L28 block, flat top pistons $100.
$750 for everything on/in a rolling shell ono.
All of this will fit into an R30 skyline. I also have MUCH more stuff and am pretty easy about parting with it. I have already taken some pictures and plan to get them up when I can get the cable to do so. Post back if you're interested with inquiries.
Edited by Blue Dynamite
https://www.sau.com.au/forums/topic/196565-dr30mr30-gear-sale-sa-only/
hey man, quick q
the gearbox manual 1? if so synchros all good?
and also do u have a gd manual mr30 sedan tailshaft?
cheers...
both G/B's are manual,
As far as synchros go one is deemed to be better than the other, although I haven't tested it I was told by the person I got it from that he thought it was really good. But if there's any way to check it out without completely dismantling it only to have to re-construct it then I'm good for that (I was going to use it in my project). Anyway that one is $50, the other one thats synchros to 2nd and 3rd arent so good occasionally is $30
I have 3 spare MR30 manual tailshafts, lets say $15 each(goes for g/b mini crossmember + other sectioned tailshaft). probably got everything for an mr30 manual conversion or two minus decent clutches.
Also got spare electric doors in super good nick if anyone wants them for $10 'all'(that's about scrap value isnt it?). They are purplish silver, (light metallic blueish). Good paint ftr.
You are in Adelaide right?
im interested in just the switches of the electric window, If they looked like the one in my DR.... Its the only thing missing in my DR and its pissing me off!!! hahaha
I got given some but they dont match, I dont even think they were off a R series ;)
If you wanna part with just the rear switches let me know. but I would like to see a pic first to see they are the right ones im after.
Which chassis / body is the rolling shell (sedan / hatch)?
Sedan, but the paint is pretty gone. The insides arent that great either but the rust it does have is meager surface and there's not much of it.
edit- ill try and get some pictures of the whole package in thorough detail asap.
Cheers, Rick.
  • 4 weeks later...
I got someone interested in the whole package so I'm going to see how that goes.
Ill keep you posted, at the very least you should be able to get a spare twin tailshaft etc..
Rick.
Hey mate, have you sold it yet? I'm after bits for a manual conversion.
Cheers
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
