hi all, rb20 motor is looking a lil tired playing with the possibility of putting a rb25 in it,
What's everyones thoughts ?
I know the 20's are lag monsters but when they hit boost theres just sumthing about them that makes you smile.
ANyways what i also wanted to know is how much it would cost to chuck an rb25 in my already rb20 powered s13.
I can get a motor with loom, ecu and all the shit minus box for 1500 or so,mechanic said he could strengthen the rb20 box for me for cheap.
So what i really want to know from people that know what they are talking about is how much it will cost to get the loom all working, with the rb25 put in. Is there anything else that will have to be changed excluding the loom, as there was already a rb20 in there?
If anyone could help us out with there experinces. Any useful info is appreciated
Thanks boys
Nathan
https://www.sau.com.au/forums/topic/196567-rb25-into-s13/
go the 25, they are awesome, ive had two RHB20 powered cars (and my gf has a stock 32 so that makes 3) and now ive got a 25 in my 32 and i love it!.
You have several options, one is to put ALL the RB20 sensors on the 25 (CAS, knock sensors, ignitor, etc etc) and use the RB20 loom and ECU, remap the ecu and your laughing.
other option is to use the 25 sensors and 25 loom, and still with the RB20 ecu (remapped and tuned to suit of course) with fuel pump, fmic, exhaust you could expect to see 200 + rwkw with a stock turbo on under 14 psi (like 12 psi) the stock ecu wont do this.
as for the box... there is no strengthing the rb20 box "cheap" unless your putting straight cut gears in it.,.. however if you plan on keeping it around 200 rwkw and driving sensibly theres no reason why it shouldnt last. with some drift and track work it will soon die.
Cheers
https://www.sau.com.au/forums/topic/196567-rb25-into-s13/#findComment-3517855
cheers for the quick response mate,
so if i go witht he rb25 i will also have to factor in remapping the ecu? which is a good $600, is there anyway you can use the r33 ecu and have it running like that?
with both the options with wiring, how much would it cost to hack up the loom like that?
how much did your conversion cost roughly excluding motor mate?
Thanks for the help
Nathan
https://www.sau.com.au/forums/topic/196567-rb25-into-s13/#findComment-3517877
are remaps cheaper then that ? where would be a good place to get remaps, so how much id it cost to convert yours or did u do it yourself?
how much do you think the whole wiring proccess would cost with getting the motor out/in?
Cheers mate
Nathan
https://www.sau.com.au/forums/topic/196567-rb25-into-s13/#findComment-3518117
Do the 25 you will never look at your 20 the same again, the loom would be an easy job for any capable mechanic couple of hundred to fit and make work, personally and this is just me but i would live with the 25 ecu and run stock boost until you can afford a power fc or equivilant the remap is good but any further mods down the track will require remapping not just retuning which is done by alot more workshops,
With conversions i recommend getting everything running sweet on the stock ecu first drive it for a little bit then start stuffing around with aftermarket ecus. i did this in mine with just cooler/intake and exhaust stock ecu stock r33 boost solnoid (6 to 8psi) made 220hp at the rears no R&R either and in a silvia was plenty to keep me happy until i could afford the ecu upgrade.
long story short put the 25 in deal with the problems that will happen and in the long run you will have so much fun :woot:
pm me if ya want any more details more than happy to help
https://www.sau.com.au/forums/topic/196567-rb25-into-s13/#findComment-3518378
Thanks boys
Nathan
i would advise not to wire up a rb20 ecu to suit the rb25det as ppl forget that a rb25det has vct and the rb20 ecu doesnt support the vct and if u search around on this site there is a thread about vtc not being connected up and the car running like a pig
unless u use some external switch to switch the vct on
just get the rb25det loom wired up to suit your car and buy a pfc
https://www.sau.com.au/forums/topic/196567-rb25-into-s13/#findComment-3518471
Or you could build an RB30 with a 25DE head out of an R32.. I did that, swapped everything over from the 20 and ran it on my 32 ecu :woot:
(It did max out a lot of things though so 550cc injectors, z32 afm and a remap later and she's driveable.. had a chipped ecu with no R&R which got me around for a couple of months before the tune)
https://www.sau.com.au/forums/topic/196567-rb25-into-s13/#findComment-3518710
so why did you go the 26 if the bias is that bad??
VQ30det FTW for ultuimate bias and power :)
for fun :) the sr was a way better setup handling wise, it took all 5 events to get it to work as well as the sr setup.... yet when it rains...... all the hard work is pointless :D
maybe i'll have a sr20 supra out there late next year.... we will see.
https://www.sau.com.au/forums/topic/196567-rb25-into-s13/#findComment-3520259
