Hey,
I need bigger injectors bad as under full load i'm hitting 97% on my injector duty. I don't really want to go to the trouble of putting on a fuel rail. I kow you can still get big injectors that screw in and I guess my question is what is the biggest size CC injectors I can fit into the RB25DET.
Cheers. She needs juice. lol
https://www.sau.com.au/forums/topic/196636-bigger-injectors/
Nismo 550's will be more than enough for your turbo (they support 300rwkw no problem).
Largest - I used Nismo 740's for mine 369rwkw.
Stock Rail, Stock Reg etc etc.
I think Sard's in the 800 are also direct-ish fit
396RWKW!!! Thats massive man! What are you running?
Cheers for the advice. I cannot wait to get all the kit on. Iv'e gone a bit silly but whatever yeah! Not long till all the parts come in and i'll be aiming for around the 290 RWKW mark. To tell you the truth i don't really want more than that. I still want to be able to drive her on the road.
Cheers
Kane
Why do tuners tell me to get bigger then 550cc if they can handle 300rwkw
im looking at between 240 - 260 rwkw
Highflowing injectors are abit cheaper then getting aftermarket injectors but i hear they arnt as good, can anyone confirm this?
Edited by SLYNE
Because they are full of shit :D
No other reason, or they are trying to sell you something that you simply do not need.
Because they are full of shit :P
Nismoid,
As I am at the stage of installing a whole heap of gear I need to make sure I make the right decision when it comes to Injectors. Can you point me in the right direction as to where would be a good place to get the standards flowed. Or even someone to talk to about this.
Thanks Mate!!
A good option for cheap injectors is 480cc ones out of manual S15's, they are a direct drop in for R33 RB25DET's.
I'm aiming for approx 260rwkw and 6 of these will easily suffice, and only costing me $280 delivered for all six.
Edited by stolen_s15
Nismoid,
Thanks Mate!!
There have been a number of threads with suppliers/prices and so on.
Just search with "hi-flow" "injectors" and you'll be right
Personally i wouldn't use hi-flowed injectors.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
