So i`m a new owner of a 89`R32 GTS-T with the RB20DET Engine and got some questions :)
Don`t know anything about RB Engines or Skylines so far, my other cars are S13 @ SR20DET and a AE86 @ CA18DET, both are not done yet, so the Skyline will be my daily Driver.
1.) The engine is running very smoothly, no weird noises, pulls good etc. (70.000 mileage) and the Oil Level is to the Max. But according to the stock gage in the cockpit, i dont have enough Oil Pressure ?
Is the stock oil pressure gage known to be shitty like in the MK3 Supra for example ? It goes only up to "2", the scale reaches up to 8 (is it scaled in Bar ?) I`ll install aftermarkt gages anyways ...
2.) Do i have to concern about the crank collar issue on the RB Engines ?
3.) My Powergoal is healthy 300 HP at the crank, i dont want to stress the tiny injectors to the max, so i guess i need bigger injectors (444 cc ?), a new turbo (the ceramic ones are not that reliable over 1 Bar i heard) and so on ... would be nice to get some infos :)
4.) Unfortunatelly, it`s an automatic ;) , but i got it very very cheap, so i`m ok with it. Anyone knows what Power the Automatic Transmission can handle ?
5.) My english is not perfect, i`m german, sorry :nyaanyaa:
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
