I have a 98 GTT and want to fit some vented front fenders but I'm not sure if I should get the GTT or GTR vented front fenders.
Anyone know the difference between the GTT aftermarket vented front fenders and the GTR aftermarket vented front fenders? Are the GTT vented front fenders smaller in terms of clearance? Would it be better to get the GTR vented front fenders so I can fit wider rims if the clearance is bigger?
The style of fenders for the GTT I'm talking about are these.. The GTR vented fenders are similar I'm guessing... I never seen them clearly. I'm not talking about the 'horned' looking vented fenders for the GTR.. just the plain vented ones. Thanks for any help on this!
https://www.sau.com.au/forums/topic/196653-r34-gtt-front-vented-fenders/
I found these on the Japan Yahoo Auction.. they cost around $235 USD after conversion. I know someone who you can get a quote from and will send them to you. Go to www.RHDJapan.com The owner is Russell Hobbs and Patrick Antell. E-mail them with the picture of the fender and they will get you a quote. They can actually get you anything. I bought my BCNR33 RB26DETT from them. If you don't know the product name you can send them a picture of what you want and they can find it and price it. I live in S.Korea so the prices are good for me.. I don't know how they'll be for you guys.
..but back to my question. What is the difference in clearance with the two fenders? Anyone fitted the GTR vented fenders on a GTT before?
no i mean if he changes his fenders to gtr ones
ah tru, misunderstood that, if there isnt a great deal of difference then might as well go for the gtt ones,
I wouldnt mind a set, at 235$US (per set?) i think its worth while, of course it would also require the re-spray
I just check my e-mail for the exact price... 31,290 JPY http://www.xxx-treme.jp/parts/fender_er34.htm I guess they do R33 and R32 vented fenders too.
R33cruiser, thats what i'm talking about. How many mm difference would it be if i were to get the do luck gtr vented fenders
vs the GTT stock fenders.
And does anyone know if these GTT vented fenders are wider or just a stock replacement.
Hey thanks 4 ur help! Much appreciated :D
and if u change ur front fenders, dont u then need to change ur front bar?
yup, I plan on changing my front bar to East Bear, bonnet to East Bear Aero and fenders to either do-luck gtr aero or gtt vented. I just need to know what the mm difference is so I can buy my rims and have them sit nicely.
Going by what i used to have on my R33, the vented GTT guards are about 20mm wider, but taper back to meet with the factory front bumper mount locations.
If you go the GTR guards, you will require a bonnet, hinges, front bumper and a few other alterations to get it all to fit. But overall wheel clearance is much more than the GTT vented guards, as the GTR's front bumpers sit out about 50mm wider than a GTT and the guards don't taper in.
we got R34 GTR guards to suit R34 GTT if you cant find any see http://www.uras.com.au/syohin/skyline.html#r34 from memory they are $649 and genuine URAS bolt on replacements
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
