Recently upgraded my GTR, and got these bits leftover.
Item: Standard R34 GTR Roller Bearing Turbos including actuators from 1999 Skyline GTR non V-Spec
Age: 41,000kms
Condition: Very good, no shaft play
Price: $950 ono
To Fit: (What car) R32/R33/R34 GTR or any RB26DETT
Contact: PM or reply please
Comments: Removed due to turbo upgrade, were in excellent running condition. No problems whatsoever. Was running 1bar boost.
I also have the following standard parts from the same car, 1999 Skyline R34 GTR .I am open to offers also. All parts are in good condition. Might have some other bits I have forgotten about. Will keep post updated.
All parts have done less than 41,000kms
Intercooler - $350
Radiator - $200
Injectors/Fuel Rail/Regulator - $300
Cams and Cam Wheels - $300
Standard Clutch/Flywheel - $250 (Never been driven hard on, still in good nick. Upgraded to due to bigger power output)
Standard Coil Packs -$150 (Upgraded to Splitfire Coils)
Standard Dumps -$200
Standard Manifolds -$300
Strut Brace -$100
Standard AFM's -$250
Airbox and Lid -$200
Stock ECU (remapped) -$350
I prefer pickup in Sydney area, or can post at buyers expense.
Edited by Blue_GTR
hey mate, could ya tell me if them turbos had steel wheels or not?? cheers
To be honest, i dont know. Is there anyway i can distinguish if it is?
*In regards to the radiator Tony, i will arrange a pic. It is in excellent working condition, just upgraded while i was doing everything else.
If they are stock ites they are not steel, if he puts a pic of the exhaust side up, I can tell you for sure .
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
