If the rear seats have been removed permentlly then you will need a mod plate as its now a 2 seater, not a 4/5 seater...
As such the rego needs to be changed and as such this is a non factory option to this vechicle then yes a mod plate will be needed...
Edit: Check out DOT's website its pretty clear about what does and does not need a mod plate.
what size tubing and wall thickness as i have the law requirements(in the code of practice book)for roll cages for street approval
note it says nothing about welding in a cage
but u will need to pad the cage with high density foam at least 19mm thick
piping must be aussie standard 1554 or better
welds must be full peneration but welds
steel min requirements
hoops 45mm diameter
2.5mm wall thickness
rear braces straight 30mm
1.5 mm wall thickness
rear braces bent 45mm
1.5mm wall thickness
I know I need a mod plate for the rear seats but I read on the internet that you need the roll cage to be bolted down to do with the "jaws of life" if you were in a roll over, but since there is no longer rear seats I was wondering if it still mattered with the roll cage
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
