hi guys im new to this site my name is steve ive just bought the gtr a few months ago it has had a full rebuild with cp pistios rods race bearings metal head gaskit ported head better valve guilds ect still has stock cams cam gears vavle springs ect stock turbos and fuel system it has a mines ecu and eboost 2 full exhuast and stock intercooler ment to of made 255kw atrw on 13psi dose this sound right? how much boost can be ran safely on the stock turbos? ive heard every thing from 12psi to 18psi i was thinking of getting it dyno tuned to 15psi will this be fine? ive ran a 12.7 at 167kmh on 12psi bad start... and 12.7 on 10psi 174kmh first time at the track in the gtr
thanks in advance steve
Edited by PHA71L
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/
Your running a VERY big risk mate. Using stock turbos on a built motor is asking for trouble and a very hefty repair bill
14psi is generally considered the limit. But as you have a built motor, i wouldnt be risking a turbo failure that could potentially kill your bottom end.
So 10-12psi would be the limit for me if i was you :D
They usually make ~250rwkw on 14psi depending on the dyno/day etc.
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3521937
As mentioned, you shoudl be careful with the stock turbine wheels. As if they are still stock ceramic items they commonly come apart and score the 3 bores its associated with. Anymore than 14psi is asking for trouble but i know from personal experience they will come apart with less. Get some steel wheel turbos :D
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3522161
yeah i think ill leave it for now and just get two bigger ones later on...the oil presure guage has stopped working now :P ive heard this is a common fault? is it the gauge its self or the sensor that dies? is it also true a rb30 sensor fits?
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3523539
are they any good? are they fully adj or are they just like a piggy back ecu?
They're a re-chiped stocker I believe.
And due to being tuned (usually) for Jap fuel, they'll theoretically be too fuel lean, and too ignition advanced.
Just as Mines did, if you have access to the ERPOM burner and SW you can 're-tune" yourself (PM CEFFIE) With a new motor (and new huffers down the road) you'll be wanting something better down the road anyway.
With a fresh new motor, id be running stock boost for sure.
Both cluster gauge and sender can be dodgey; with that new motor id get a aftermarket one asap.
Edited by GeeTR
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3525325
motor is well run in 8000kms now... it dose seem to run rich! i would change the ecu if i go bigger turbos...
ill get it dynoed first and check every thing out,
the gauge when it was cold it would work as normal then it stated to flicker to 0 and were its ment to be...then a few days later it stopped flickering.... once it was warmed up it would drop to 0 but no warning light or any thing, and now it is on 0 all the time... ill change the sensor first and se if it fixes the problem.... dose any one know if its true the rb30 sensor fits?
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3526560
  • 1 month later...
had it on the dyno for a dyno day mad 290hpatrw and it was very rich! 10s and dipping to 9s afr
mines ecu is only a chip also hmm time for the power fc i think and injectors... how much hpatrw will 550cc inj flow on 2530s?
a tuner also said with the power fc and a tune to 16 17 psi on stock turbos it will make 350rwhp fueling it up a bit more to cool the stock turbos for the high boost any thoughts?
thinking i will run 15psi max
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3625965
fair call...well what power have people made on the stock turbos? and how much psi? and other mods ect
hey r33 gtr power fc, cam gears, exhaust, filters, 170k 1 bar still on ceramic turbos, 240kwaw, 1.2 bar 280kwaw.....running quite rich,maybe i have freak standard turbos......next week putting on 2860s......sweet, will let you no condition of turbos when they come off haha
Edited by donkey
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3630997
nice! i think cam gears are on the list of mods as well! yeah mate that was me... you have me to keen now for 2530s! power fc asap first but
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3633255
who's dyno and what brand......
https://www.sau.com.au/forums/topic/196817-r32-gtr-tuning/#findComment-3633320
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
