a while ago my mate put my bov on my R-33 which is a turbosmart vee port.
where you can adjust it to harder or softer he twisted it all the way to the soft setting and past the red mark where it says not to,and i told him that he went to far he reckons it wouldnt do anything???
i have since taken it off cause it was causing stalling but is it ok or would it be damaged?
i heard that if you go past the red point it damages the thread.
cheers.
https://www.sau.com.au/forums/topic/196826-is-my-bov-ok-or-screwed/
The red mark is just there for you to not unscrew the whole bov apart as far as I know. If you keep going with the unscrewing, it'll just take the top part of the bov off and you'll see the bov's spring.
cheers.
The stalling is likely just because you have a BOV that is venting to atmosphere instead of plumbback. So a search on the forum - been covered many times. Pretty sure it can be fixed by tuning with a piggyback or replacement ecu.
I'm also pretty sure you'll get better performance from the stock one and wont be attracting attention from authorities and from pedestrians who will hear the pshhht and turn around expecting to see some teenager in some fully sick ricer...
your choice i guess :D
Edited by pixel8r
well thats good news cause it cost me $400 from repco,just glad it aint money down the drain
yeah ive been thinking of getting the car tuned after christmas,can they tune the factory ecu for the bov?
i live in grafton where there are a few turbo cars getting around...skylines,subaru etc and they all have atmospheric bov and im probably the only guy without one.
thanks for the info.
As I had responded to your other BOV thread... atmospheric BOVS are a hassle (learnt the hard way as I bought one not too long ago... mate, if you get a Greddy emanage or a Apexi PC or most other ECU's you can get this tuned in... that's if you're willing to buy an after ECU unit and willing to pay $450 for a tune... the easy alternative, just put on a plumb-back BOV or put the stock on back on...nothing wrong with the stock one...
I wouldn't leave this issue for too long as the stalling will increase.
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
