  • Replies 115
Posted Images
too late,my was covered with blankets but it still ding the crap out of it,even on the front right guard right on the round part its dinged so hard it cracked all the paint.
we had he size of tennis balls,my mums camry has a smashed winscreen,so does about every other car in my neighbourhood and cars i seen driving.
would love to be a paintless dent romover this week.
I'm in Baulkham Hills and we got hit pretty hard.... car was in garage luckily. Sorry to all that got hit.
Some pictures I took attached.
I took the two "garden pictures" about 5 minutes after and they'd already melted a fair bit. They were 20c pieces round when first coming down, nasty stuff...
Edited by TommO
I was just in parked in Pymble when i heard it starting...Ran to the car, and luckily there was a dude(Matt) that works for Dominos that parked his wrx and another Peugeot under cover behind the shops and showed me where to drive in. I just stopped the car when the hail started getting massive....phew soo close :D
sorry to hear about so many pl with dents n smashed windows tho :D
Tennis ball sized hail here...
I got smacked in the mouth by one while trying to cover my car...Felt like I got punched in the face. f**king thing came at me sideways.
I have dents on my roof and passenger quarter.
Oh, and a swollen bottom lip.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
