this car did not have one sctatch or dnet on it. the other reason why i also jumped out there in the hail like a crazy person is because i only have 3rd party insurance on it and if it ended up like our three other cars "write offs" next to it, it would of been even more damage to fix. and more damage means more $$$. luckaly i have alot of pannel beaters and spray painters in the family. but wat pisses me off even more is that it just came out of the workshop at hills motorsports and spent a few $$$ on friday with all my new bits on there and i cant even enjoy it properly.
mabye its time for comprehensive insurance???
  • Replies 115
Posted Images
I was one of the lucky ones in 1 respect, I live in St Marys and got nothing but rain and wind... But on the other hand I work in real estate as a property manager and have had to deal with the 60+ properties that have been severely damaged, I really feel for those guys and the owners! :bunny:
sorry to hear everyone...
yea luckily my car is still in storage at the mechanics waiting to get fixed. my parents alfa got raped.. smashed windscreen, dented roof, bonnet, guards etc. it was pretty bad as im in the castle hill area where also the power was out for like 4-5 hours.
I was one of the lucky ones in 1 respect, I live in St Marys and got nothing but rain and wind... But on the other hand I work in real estate as a property manager and have had to deal with the 60+ properties that have been severely damaged, I really feel for those guys and the owners! :D
I'm in Colyton/St Clair area and the stones were only small-ish but hard enough that they dented the shit outta my roof and the pillar between the roof and top of the doors... weird that one side of the place got hit and the other was basically untouched.
Im guessing they couldnt provide a licence/documentation to prove that they are accredited workers?
There was a warning on the radio about tradespeople quoting and then receiving deposits for the the work, then pissing off with the deposit!
most off the houses in my street have broken glass..the obrien glass guy has been to heaps of houses on my street
anyone got a CF bonnet for fit r33 gts-t S1?
It's been awhile but last time I was at Unique Autosports they had one. I'm pretty sure Powerplay can get an awesome Eastbear one in too (pricey, but worth the money, and definitely hail proof ;)...I should know).
it is???...........wow
my car fuct!!!!....roof has heaps of dents and bonnet is a write off, so im gonna get a carbon bonnet
sux to be me.....i was working and the hail car out of nowhere
first thing i did was grab cardboard from the rubbish bin and then ran and put it over my roof...i had to hold it on my car
now my body is covered in massive bruises...and one massive hail stone hit me in the neck and i cant turn my neck
Talk about throwing yourself in front of the one you love.
:dry:
When you have A pillar and roof damage the car is write off as from then on it has a weakened structure and wont be legal for road use, its also void for insurance.
I.e it will snap in half in a head on and squish ur head off.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
