  • 6 months later...
Paul! Do you still have tha Apexi led flashing gizzmo that I won ages ago?? lol
Yes I do, I can drop it round after the long weekend, PM me your address again.
Sorry about that Charlie.
  • 1 month later...
Im unable to edit the original post to say the inj are sold, so except the INJ if there is no line though it I have it.
Thanks
This is whats left. with a price drop
Apexi PFC Boost controller (as per pic) $100
Turbo’s STD Balled R34 GTR VspecII 20,000km old, pair $650
CAM’s STD R34 GTR VspecII 20,000km old, pair $300
(Great upgrade for non vspec apparently 255 deg instead of normal 250 and GTT')
ECU STDR34 GTR VspecII 20,000km old $100
AFM STD R34 GTR VspecII 20,000km old, pair $75 1 is slightly damaged with a cracked and repaired hole, but working fine
HKS Metal air pods from R34 GTR pair $100
Boost Solenoid STD R34 GTR VspecII 20,000km old $20
AFM STD R33 single, please try before you buy $35
Fuel pump R32 GTR $140
Aircon/climate control Module R32 GTR $100
Variable cam sprockets R32 GTR pair $80
HKS air pods (Plastic from R32 GTR pair $60
AFM STD R32 GTR pair 80,000km $60
Front strut brace R32 GTR $50
Variable cam sprockets R32 GTR single exhaust $50
Turbo R32 GTS working $100
Turbo R32 GTR BLOWN, needs rebuild single only $50
Turbo SR20 NEW and not used $400
Fatz bargain basement!
I know you want them Fatz, just because they are cheap!
Sump baffle/de-fuser STD R34 and R32 GTR each $40
Spark plugs iridium heat range 6, 5,000km old 6 units $30
Horn R32 GTR $20
Thermostat 76Deg R32 GTR $20
  • 1 month later...
OK,
R34 Turbo's, AFM and ECU sold. Also R32 Cam sprockets
CAM’s STD R34 GTR VspecII 20,000km old, pair $250
(Great upgrade for non vspec apparently 255 deg instead of normal 250 and good for the GTT)
Fuel pump R32 GTR $100
Horn R32 GTR $20
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
