im in the market for a late model r32 GTR.
what i want to know is are there any OTHER differences rather than just brakes and wheels that they were released with.
are there any identifiers on the id plate to say its a vspec, like wats to stop some1 putting a set of brembos on and saying its a vspec... maybe any codes or somethin, i dont know..
hope that clarifies wat i wanna know and am asking.
thanks
https://www.sau.com.au/forums/topic/196857-r32-vspecs-and-non-vspecs/
thanks
Im pretty sure if run the VIN thru Nissan FAST it would tell you if it is a VSpec... but there is always the possibility VIN plates had been swapped, tho unlikely.
exactly...get the VIN# and post it up in that thread we can check it out. the rest can be swapped pretty easily.
BTW, unless you are a collector that wants to keep it stock, don't bother paying more for a 32 vspec - you could upgrade brakes and tyres yourself for less than the additional cost - and the vspec brakes arent really a big step up anyway.
ye thats wat i wanted to kno thanks! im gonna change it all anyway, brakes, wheels etc jus wanted to see if there was anything special about them haha or was it just the brakes and tyres....
ive found a 93 vspec with 34 gtr wheels and 2560 turbos std suspension for 22k or a 11/1994 for 20k immaculate as they come with 33 gtr wheels and tein coil overs, im tossing up between the 2, the 94 is absolutely clean as but the vspec i think needs some new uni joints or somethin, feels a bit funny as i shifted gears, like a jolt... but other than that it is very clean also... dont kno which one to get!
ill be stripping it down, flaring the guards, painting it, and swapping my running gear and interior as i dont want my car off the road any longer hence looking for a late model immaculate base.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
