I was told to NEVER machine a flywheel. Apparently even the smallest amount of machining can disrupt the integrity of the metal, and when a flywheel comes apart at 7,000rpm+, they can take your feet off, or various other nasty things.
We used to machine flywheels on a surface grinder while it was fixed on a bed with a hi-speed rotating stone wheel buzzing over it (and lots of coolant washing it simultaneously).
The deal is though, we only did it for the street boys and girls.........the serious race boys would always buy a new one!?
All clutch and brake.
$50.
As above; it really depends what your doing with the car. I've always had mine machined and never any problems.
The RB flywheels are fairly foolproof; if the flywheel has been machined near dangerously thin the clutch plate will knock the flywheel bolts so you can't use it anyway.
The bloke down at all clutch brake said the metal used in the RB flywheels is quite good and doesn't suffer the problems of exploding flywheels like other manufactures do when machined.
Its only what I've been told by all clutch brake. :P
In saying that my flywheel has been machined 3 times now and is very close to the bolts so I'm looking at a flywheel with near factory weight. The 3ltr doesn't really need a lighter flywheel; I'd prefer to keep a bit of weight on the end of the crank.
Well I can tell you now. When i got my flywheel machined on the clutch change, the guy told me he had to machine the absolute shit out of mine because it was dirty as. The car had been revved to 7,000 rpm (or just under) plenty of times after and felt alot better than when I first bought the car.
I was also told this, but it is for CAST flywheels - I'm unsure of the RB flywheel's construction.
They still go bang.
I did approx 35x 7000-8000rpm launches (about 30 of those at a prep'd drag track) in my R32 GTR in 8mths without any issues (best feeling in the world) but #36 has cost me about ~$15,000 (flywheel shattered, ruined my firewall, chassis rail, engine, gearbox, inner guards etc etc - the car is effectively a write-off) and has very likely put me permanently out of the import 'game'.
Pics in this thread
Yeah I did see that.
BUT.. That thread has also been cleaned up with references to the bloke who sold the flywheel/clutch combination.
Apparently it was a manufactures fault with the flywheel.
I'll try to dig up some info to be 100% sure. But from memory it wasn't a standard flywheel.
As has been already noted above machining the standard flywheel can lead to serious issues. For that piece of mind buy an aftermarket lightened flywheel from japan it's really not fun side stepping a clutch at 8000rpm and having chunks of metal fly around the cabin.
That gtr is still in the garage being repaired, my other gtr ive never dumped the clutch and havent revved it over 6000rpm and it certainly will never be seeing any kind of track regardless of what clutch/flywheel it has - 1 broken gtr is enough for me I dont want 2.
This is how close it came to removing my feet:
PS - My flywheel wasnt machined, just had a small crack in it and along with a high clamping force single plate clutch and over 30x 8000rpm clutch dumps was enough to shatter it so machining would have made it even weaker.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
