Final 07 Coffee Photo Shoot Meet
53XYN
 Share
  • Replies 67
Sounds good guys we will have to meet at Hyperdome as the photographer wants to get it over and done with since his bringing his studio lights in
Meet at Hyperdome northern End NOT COFFEE SHOP (Coffee after photoshoot sorry for sudden change guys )
If anyone has any problems call me on 0400565607
IF YOU ARE SMART YOU GUYS MUST GO TO THIS ON THE 22ND!!!
we had an amazing night last night. this photographer is the real deal, he had a massive set upwith 2flash towers and all sorts of gagets!this is a must is ur into ur car and if u dont take this oppertunity ur a silly bugger. these are pro magazine style photos this guy is doin, for which his usual price is $400 PER CAR!! for like less than 10 pics! and vish has organised this for us wher we get prob 20+ pics done for $5!!!! ahhhhh! plus you can tell him what u want more pics of, like engine, rear, front, side or wheels etc etc!!
DO IT GUYS, GO, COS U WILL CRY IF U MISS OUT.
Sounds like it was fun, sorry i could'nt come i had to have xmas dinner last night with my family as they are going OS for the next 4 weeks.
Any sample images Vish'y also whats the guys name or business name? Chances are I know him....
X2 this guy knows his shit and the setting he chose was bloody brilliant. I doubt you will ever get another chance to get pics like this for this price.
I have to give it up to everyone that joined in .. you all kept SAU's strict code ie no noice skidz loud music etc.. awsome crowd more then happy for everyone to come again on this comming sat ! the more the better :)
 Share
    • I did manage to do this without removing the engine or front cross member, but I had the advantage that the exhaust manifold was removed. I am not setup to support the engine from the top or remove it. 1. Loosen the engine mount nuts so they only have a nut of thread. If it is a manual, I think you have to remove the gearbox to engine support brackets. 2. Jack up the engine off the bottom idler mount. Jack it up till the end of the slot and nut on the mount. You need this clearance to get the pan out at the rear of the engine. 3.Break the sealant seal to sump. I found a oil pan separator tool helpful to get it started. 4. The oil pick up can be removed with the gap available.  5. The oil pan can be removed now. 6. Before assembling, do not apply sealant to the oil pick up area as your hand will rub it all off but apply to the other three and a bit sides. 7. It is a two man job to put the oil pan back, with the sealant, as you do not want it to touch anything and rub off. 8. With one person supporting the oil pan the other can fit the oil pickup 9. Apply the remaining sealant. This would be more difficult with the manifold or turbo in place, but I think it could be done. As you can see my sealant is a bit ugly, but good enough to seal. 10. Lift the sump up to the engine and bolt it on. We found it was easier to use two long guide bolts at each end to get it nice and aligned without touching.
    • I find building an exhaust a really satisfying job! Looks nice!   Did you consider using an oval pipe to get the same cross sectional area but keep it above the chassis rail?
    • @Dose Pipe Sutututu Sounds good.  Just double checking with the pull up resistor indicated in haltech's info sheet for their SSR - https://www.haltech.com/product/ht-030202-solid-state-relay-100-amp/  I'm guessing that would only be if the ECU did not have an internal pull up resistor? Their instructions are pretty strongly worded lol "1K pull-up resistor MUST be fitted."
    • I wouldn't think you would need a flyback diode, as it's an OEM replacement parts for a fan controller/relay on a Dodge. Another tried and tested option are the Volvo XC90 (or similar) fan controllers.
    • Just checking, with this would you need anything else to get yourself up and running? Do I need a flyback diode, pull up resistors or anything else?
