  • Replies 69
Originally posted by Cool Hand Luke
haha, i could eat 50psi, but my stock bov wont permit it :P.
Im going to buy the RB25 turbo, found one. Is there any way from the outside with the intake pipes on that i can tell its a 25? Or do i have to measure the compressor wheel?
I can answer that for ya..
An RB25 turbo has the following on the compressor cover.
45V4
I bought one myself, got it put on, runing 13psi...
I think that it's a great upgrade.
good luck
Originally posted by Bl4cK32
whose wasting who's time, you're the one who slings shit then says, "My car runs 12.8, with less than 2k spent on it"
As much as I hate to admit it his car does run 12.8's and he hasn't spent much on it (although this is in a small way due to the fact that he works a at performance shop).
He has a big fuel pump and an ecu remap, possibly a fuel reg with higher pressure to extend the facotry injector limits.
R32-GTS,
lets get back to being civil, you have some good information to contribute to those with the RB20's (not that we need anymore whale bashing):P
R32-GTS claims 300kws at the engine which sounds reasonable with std injectors.
Say factory 110rwkws - 160kw at the engine. So 200kws at the wheels - equates to a very rough 300kw at the engine.
RB30 NA's dont put out 120kw;s at wheels. I had one with a few mods was lucky to push out 98kw;'s at wheels.
The engine i was referring to was an R31 Skyline RB30 with the RB25 Twin cam head, inlet manifld and RB20 ECU. So i suppose that makes it an RB30DE as oposed to Aus model RB30E
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
