ok so ive gotten a million and one quotes on how much replacing the clutch in my GTR is going to be labour wise, but my problem is noone i talk to seems to know much about the car itself. Does anyone know a good place to take my car around sydney area?
https://www.sau.com.au/forums/topic/197026-clutch-replacement/
ooer interesting did you find an aftermarket clutch for the z? first time I changed mine i had to go standard nissan.
And you must change the flywheel as well. it is dual mass and will blow up sooner or later which means box out again anyway.
For the GTR clutch....where are you? there are lots of sydney workshop threads. And I've got a clutch for sale that would suit
Hi Duncan,
I am gettin exedy organic clutch with lightweight flywheel combo. Yeah i was told to change the flywheel as well :-)
Edited by R34NOS
  Rozza said:
im in north sydney, and wouyld be interested in buying a clutch for sure, just need a standard one until i upgrade everything down the track heh.
Yep, go powerplay then.
82 - 88 Victoria Rd
Drummoyne NSW 2047
Phone: (02) 9819 7555
Fax: (02) 9819 7055
Email: info@powerplayimports.com
yea going to powerplay. so much difference in quotes though, its amazing. the places that did not know gtr's were like need your car for like 2 days and 800 dollars for labour. powerplay said about 300 for labour and 2 and a half hours haha.
Excellent work! My poor baby has to go back in there soon to get my box rebuilt.
Yeah $300 is a good price and i got quoted from 2 places same price. Some places may need your car for 1 day simply because its xmas time and everyone wants their car back before xmas. Anyways good luck
getting a heavy duty clutch installed at northern beaches performance today in my 33 gtst, think they qouted about $300 for approx 2-3 hours work. would highly recommend them, and it would be alot closer than drummoyne.
why don't you just get a heavy duty clutch if you're planning on upgrading down the track? :rofl:
got my Exedy 5 puk button kit installed by trent last week, it's awesome, so light and easy to use. was expecting something very heavy and a bitch to use in traffic
if you're having trouble getting a hold of northern beaches performance on the landline, try trent's mobile (on website). quite often he's got an air compressor going or something and can't hear the phone.
and i think he mentioned sam isn't working there anymore
  Rozza said:
so they put the clutch in but cant get it to engage and they have no idea why.....had to happen to me lol, my car is cursed
dont worry dude had the same problem when i did mine i had to put the box in and out five times and then it worked :)
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
