R32 GTST 217.2KW AT 11psi $21k
93 model gunmetal grey 5speed
rb25 motor with 48k
has made 217.2KW at wheels will run easy low 12s
600,300,75 front mount cooler with polished stainless steel piping
stage 2 GCG turbo 450hp
2litre surge tank, bosch 450hp fuel pump
17" white deep dish circuit racing wheels
DBA gold slotted and drilled brakes all round
Apexi air fuel controller
Apexi boost gauge
Sard turbo timer
three inch exhaust off the turbo, stainless muffler
top of the line kenwood head deck
bilstein suspension
Malpassi fuel pressure reg
sunroof
GTR front bar
5 button ceramic race clutch
HKS super seq bov
very clean car all round, regretful sale $21,000 ono contact josh on 0410690026 Sydney
https://www.sau.com.au/forums/topic/19703-r32-gts-t-rb25-very-quick-car/
  • 3 weeks later...
  • 1 month later...
has 420hp turbo, apexi power fc computer, apexi electronic boost controller, wing, front lip, lowered, full exhaust, cd player, amp, splits, black with red pearl, low kms, always serviced, sti arms and sti close ratio gearbox, etc etc.
Yeah mate can you send me pics, my 32 with much the same stuff that made 316kw was stolen and burnt out waiting for the insurance pay out b4 I can buy. [email protected] Cheers Matt
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
