Here are some photos of my new wheels
Work VS-KF
18x10 +20 rear with 235/40 tyres
18x9 +26 front 225/40 tyres
I am still to add a 25mm bolt on spacer on the fronts. Also lowering the rear 1 circlip (8mm) and front 2 circlips (1.6cm). In these photos I have my old wheels in the boot, thats why it sits at that height (which is the one I want)
Guards are completely stock, still have the lip. I am going to lip the rears as it rubs slightly over bumps. With a lip, it wont rub at all.
Will post up photos after lowering/spacing.
Edited by AlexCim
https://www.sau.com.au/forums/topic/197030-got-some-new-wheels/
I am not normally a fan of chromies either, but I think they suit.
I lowered the front 2 circlips but it didn't go that much. I left the rears, I am going to both of them as is. A little lip and it will be sweet on the rear
I probably wont lower the car beyond now as I still give it a thrash through mountains and I want to avoid bump steer/wheel smashing on front gaurd. The 25mm spacer at the front did wonders!
Going to look for a series 2 Dayz kit if anything, will probably wait to get off my P's for that (April)
Edited by AlexCim
Those wheels are mad Alex!
The fitment is not to my taste but I am an old man and scared from too many Kingswood rims being fitted to early model Commodores and sticking out past the guards...
I do see the point though, that is some great dish.
haha, if anything I would put 215/45's on the front. The fronts now would hit the gaurd thats why I cant lower it too much beyond where it is.
The rears wont fit anything below 235/40 as I am only lipping the gaurd, I am not flaring/rolling it at all. 235's fit perfect under the rear gaurd.
You running yours RWD now Alex?
No, I am not. But I don't give a shit about my gearbox anymore. Its dieing anyway and I want a manual box (I am of the theory, don't fix/replace until its TOTALLY rooted)
what happens when you go over bumps? dont you get mad rubbing?
Slight rubbing on the rear at the moment, I am lipping my guard tonight (just bending the inside lip up, not flaring or rolling). Once that lip is bent up, HEAPS of clearance (What I deem as heaps :devil:)
The front wheels fit just outside the guard and my front shocks are pretty stiff (SK GB), as of yet to bottom them out. Either way, both wheels camber in to clear. The tyres on the front now are pretty square, even with a stretch (tread design). The next tyres should be more rounded.
My theory about fitting wheels is get the wheels first, then adjust the car around to suit. If thats with tyre stretch, negative/positive camber, lipping, rolling, flaring etc. All I checked on these was inner clearance to the shock, of which there was plenty both front and rear.
The fronts don't scrub inner or outer guards either.
Edited by AlexCim
it won't hurt your auto box, it would hurt the transfer case if anything and the operation of the AWD system. But 225/40 to 235/40 is bugger all difference in height, about 4mm. Even less with the stretch on the rear sidewalls. I doubt it will be a problem at all.
mr plod will like them too I reckon, as will an insurance company if you have an accident with tyres fitted to rims outside the maximum recomended width. hopefully it never comes to that.
  • 4 months later...
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
