Went down to see the boys at Creatd Motorsport last Friday just to get a check on the car to see if anything was up and a readout.
engine/performance wise only mods are:
-Gtech (Hybrid copy) FMIC,
-Drift Pod (with induction piping where old factory intercooler pipe was)
-boosted about 10.5psi
-full exhaust
stock: ecu, turbo, fuel pump, injectors, coils ect..
first run managed 196.4rwkw, was shocked as i was only expecting like 180. Then the second run it pumped out 200.5rwkw.
they said air/ fuel mixs were really good, and the curve was exeptional for a stock ecu with the mods
so yeah extreamly happy with the result.
just thought id share.
cheers
Edited by jake33
https://www.sau.com.au/forums/topic/197039-dyno-result/
MBS206.. i call brand new state of the art dyno dynamics dyno :P i made 206 on that one and 205 on another (the other was without pfc/straight thru exhaust/injectors) and ran 13.1@105mph :P
the tuner of that blokes car wont make up crap to keep the customer happy.. if the car makes 20kw or 400kw, then so be it.
Edited by LTHLRB
https://www.sau.com.au/forums/topic/197039-dyno-result/#findComment-3524750
like mentioned above, numbers are numbers, track speed at the 1/4 mile is a good indicator of its true hp, not saying your result isnt accurate.
imo a dyno is just a tuning tool, i've seen far to many variences from dyno to dyno to believe hp readings. The only way to accurately compare cars on a dyno is to have one after another on the same day and same dyno, otherwise there are too many variables.
as long as the afr is safe, and its not knocking you should be happy
https://www.sau.com.au/forums/topic/197039-dyno-result/#findComment-3524838
Well yeah im very happy. Ha yeah the guys at Creatd said people would label it as a 'happy dyno' I even called B/S to it when i was there.
As said above, its a brand new dyno (6 months or so..) and has been checked/serviced and calibrated twice according to them. They claim its is extreamly accurate.
Considering i leterally drove it in and it went straight on to the dyno, with no fiddling, with timing or anything, and that was the result, im happy.
They almost didnt believe me when i told them the ecu was untouched and they suspected a re map, (hence why they checked after the first run) and for what mods im supporting we were expecting atound 170 to 180.
They also said its rare but not completely uncommon that it makes this sort of power considering the minimal mods.
some people only get like 160, where as some people will get 210 or whatever.. same car, same mods will have different readings due to condition and how well they are taken care of.
At the end of the day. its just a power run, im happy.
cheers
Edited by jake33
https://www.sau.com.au/forums/topic/197039-dyno-result/#findComment-3525367
no.. above said shorts have the usual sport short, inner undie section.
thus eliminating the need for actual undies.
Also, I will add that this result was with loss of traction.
If I had a new pair of Nikes and deflated the air bubble down to 15 psi, I would have no doubt cracked the 160kw mark.
AND
intake temps were 23 degrees and on a few odd occasions, the exhaust temps went up in small burst to about 45 degrees. :D
I think I had a few missfire issues on that run..
Next dyno day, I will have the new nikes, remove shirt for extra weight reduction.
I'm thinking I might add a bit of octane booster... I saw soem the other day called Mars... it came in bar form.
"I only eat things in Bar From"
https://www.sau.com.au/forums/topic/197039-dyno-result/#findComment-3525801
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
