Hi everyone,
My diff currently makes a loud "clunk" sound when getting on and off the power, it also has diff whine while driving about about 60km/h.
It's fairly loud, not too bad.
However the clunk is kind of worrying and has been there since I got the car from Japan so we pulled the diff out on Sunday and a mechanic is having a look at it but he's not familiar with these diffs.
Can you identify the diff from the pics?
Its out of an R33 GTR (non Vspec).
And should the ends of that cross pinion be round or square on the ends? The pics not too clear but its ends are square which might be what is causing the clunk...
Sorry for the quality of the pics, I was not the one taking photos so these are the best I can get for now.
Any help appreciated as always.
Regards,
Gareth
the spider gear (x shaped) support looks fine as does the housing but i really need a pic of the casing to identify 100% what it is.
The spider gear support your referring to is the last picture isn't it?
Currently the diff has a lot of preload, which would explain why it skips on corners, not quite sure what was causing the clunking and whining yet.
the ends are supposed to be square they sit in the cut outs of the 2 halves. in the first pic where you have the centre sitting on half the carrier, is the carrier worn in the centre area? i dont have paint atm so i cant pin point it. there looks to be a fair amount of crap in there but the oil looks cleanish, was there much metal filings mixed in the oil, as for the noise at 60km/h it could be crown wheel an pinion or tyres, while the diff is out check the tailshaft uni joints if they're buggered they can make clunking noises.
There were no metal filings mixed in with the oil. The diff looks pretty new on the inside.
Tyres are brand new, have only done 300km/s or so, Dunlop Le Mans, and I'd be worried if they made a high pitch whine rather than a bit of road noise :D
Apparently crown wheel is ok too so maybe the diff just needs its pre-load adjusted a little. Which may be done by removing a clutch plate and that has me a little concerned, I will see how it goes.
Thanks for the info.
The diff has 6 plates on each side so one may be removed to reduce preload.
I will put some photos up later.
did your builder by any chance check the crown wheel runout with a dial gauge/or take a tooth reading(eg put diff shit on the teeth turned it round a few times and seen how it ran) before he pulled it all apart to see if it was slightly bent?
New pics of the diff apart...(after washing :domokun:).
Does this held identify the diff? There's currently 6 plates on each side, we might be removing one so there's 5 a side and a little less preload...
looks quite possibly like a std gtr mech diff. it isnt shiny enough to be aftermarket. as for the clunking mechanicals clunk when the wrong oil is put into it. has the oil been changed recently or when it started clunking?
No, we will do an oil change next, the front diff has had an oil change and it had an unusual clear coloured oil, so did the rear diff.
Are you sure this is standard?
As the diff is it never unlocks, ie. turning corners one wheel just skips which is a little annoying and you hear a groaning sound from inside the diff.
Reversing up into the driveway the diff groans and makes a sound like something is grinding (a little bit like a scraping sound) and there feels like some vibration as well from the rear, also the front wheels don't engage (or at least I haven't noticed them engage) and the wheels spin if they are off the ground....(front wheels do engage lightly when in a straight line and accelerating hard or accelerating on cornering so ATTESA is still working). I've seen the noise description on some aftermarket diff's.
Do you know how many plates stock diff's have, 6 on each side of the diff?
Taking one plate out on each side seems to improve things, and it should still lock fine when accelerating harder so this is probably the way it will be rebuilt.
Thanks turboedsloth, I found: http://www.skylinesaustralia.com/forums/Gt...tml&hl=diff
And some pics of the R200 with Nismo clutch plates on:
http://translate.google.com/translate?hl=e...ficial&sa=N
So its possible he has put aftermarket clutch packs into a standard diff centre (maybe) or its been shimmed tighter, I dropped Cubes a PM, R31Nismoid is the other one who has had this done according to that thread.
Ok, got the diff back in now, 1 (single) plate has been removed.
It locks *less*, so I can roll back a little easier and reverse out of the drive way without having both wheels lock. The front wheels also engage a little more at low speed, previously one rear wheel would spin in the air and the front wheels would hardly engage.
Used redline oil this time, clunk is a little less loud, diff whine is quieter. The lock engages very easily with a tiny amount of power but when reversing or cornering at slow speed / light acceleration it doesn't appear to lock.
Is the clunking sound normal for a GTR 2 way mechanical LSD?
I find my GTR rear diff to be rather tight as well. It's always trying to lock up around corners and get the car to go sideways, and also when doing tight turns it keeps trying to lock up (I'm struggling to explain it). Factory GTR diff....
  • 5 weeks later...
Ok diff housing has been machined by 20thou and rebuilt, it doesn't groan during slow speed reversing.
However it locks at slow speed corners still, at least a little and you can sometimes here one wheel "skip" a little.
Overall its better.
Anyway, the clunking noise appears to be coming from the drive shaft , probably the CV joints.
So good luck if anyone else has the problem :D
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
