got r34 auto sedan, its non turbo.
theres a snow switch jus near the steering column can sum1 tell me what this is as to compared with 'traction control'. on ignition i dont have 'tcs' or 'slip' or any thing like that light up. only thing ive got is 'snow'. what exactly does this do and is it same as traction control. checkd fuse aswell and there is no traction control fuse.
any1 out there know about this ??
thanx
https://www.sau.com.au/forums/topic/197062-r34/
Snow mode makes you to take off in like 3rd gear. Ment for snowy/icey roads so helps you to keep traction when taking off. Traction control only kicks in when u break traction and the car takes off in normal gear, being second or first.
https://www.sau.com.au/forums/topic/197062-r34/#findComment-3525169
so does that mean snow and traction control is only active during take off's. what about normal driving speeds?
what if u take a corner in the wet and the tail steps out, will both/either system try and correct traction
i know i can try all this out but wanna see other ppl experiences.
https://www.sau.com.au/forums/topic/197062-r34/#findComment-3526792
snow only active untill trans shifts to 4th...when you slow down to a stop, it won't go further than 3rd. So basically it just holds 3rd until ur high up enough in the rev range to shift 4th. Traction control is always on, unless you take it off. It works in unisen with ur brake system and acceleration. (not sure bout skylines as new to them). I know with commodores, you go around the corner, lose traction, it will force the accelerator pedal against ur foot via an actuator so u back of acceleration and then module applies individual brakes untill the car regains full traction. In regards to both systems, going into the corner and sliding, traction control will be main factor in evening you out. Snow mode only holds gears. Hope this is somewhat correct and whut ur looking for.
https://www.sau.com.au/forums/topic/197062-r34/#findComment-3526895
Not sure how similar this is to the "snow" button in stageas? In the stagea the snow button basically forces it to start off in 2nd gear. This is basically to ensure you get traction on slippery surfaces since the car wont accelerate as quick off the line in 2nd etc.
Traction control works similar to ABS but the other way round. Ie. where ABS tries to apply the brakes on and off to maximise grip when stopping, traction control will accelerate on and off to maximise grip when your foot is on the accelerator pedal. Pretty sure this traction control system only works when the car is accelerating, so it wont necessarily help if you're in a skid or anything - that depends on your ability too.
Basically, here in australia snow mode is virtually useless (unless you happen to drive in snow - i'm guessing you wont be anytime soon). So leave the snow mode off and for safety leave traction control on unless you want wheelspin :banana:
Interestingly the RWD stageas have traction control but the AWD ones dont. Almost impossible to spin the wheels with ATTESA though so the Nissan engineers probably deemed it unnecessary :bunny:
https://www.sau.com.au/forums/topic/197062-r34/#findComment-3526936
mmmm interesting replies, makes sense though...i think
so to sum it up, snow mode already assumes ur gonna break traction therefore always uses higher gears to get drive AND traction control is always monitoring levels of grip and adjusts accodingly. Howz that sound???
i suppose snow mode wud help a little bit in the wet cauz its in taller gear and harder to wheel spin but obviously traction control is the ducks guts in the wet....
im gonna try this out and see what results i get in the car...
https://www.sau.com.au/forums/topic/197062-r34/#findComment-3526981
Traction control should be plenty enough in the wet. Snow mode will just make your car reeeeally slow on take-off.
https://www.sau.com.au/forums/topic/197062-r34/#findComment-3527975
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
