HEY NUBCAKEZ ;)
im after a dump + front pipe upgrade ay, i have been looking round and trying to do some homework n shit on it but i still cant really decide, and i after some opinions and experiences with these setups coz i know some of u guys have bought these items and it would help heaps for some feedback :P:D
MY OPTIONS
* these FLYING PERFORMANCE 3" DUMP AND FRONT PIPE IN ONE, mandrel bent dump & front pipe in one LINK HERE FOR PIC!! $199
* or FLYING PERFORMANCE 3" DUMP split dump setup LINK FOR PIC!!! $99
* also on ebay i found GKTECH 3" Stainless Steel Front Pipe with FLEX & Dump Pipe COMBO LINK FOR PIC!!! $239.00
prices excluding postage ay >_>
my car setup, 4dr sedan r32 with rb20 with stock dump pipe and front pipe, 3" cat back zorst + hi flow cat, and twin drift pipes, also an r33 rb25 turbo @ 14lbs :P
wat are your thoughts, remember im just learning n shit atm rofl D:>
cheers JEZ :)
Edited by 32JEZ
https://www.sau.com.au/forums/topic/197069-split-dump-pipe-single-dump-pipe/
search bro. from what ive read. the split dump is better for circuit/track and bellmouth is better for drag....or so the articles say.
search. easily 2 dozen topics out there
..also interested to know how your runnin 14psi with nissan R&R coming into effect anything above 10psi????
Edited by r33cruiser
HEY NUBCAKEZ :( ...
I reckon, you should search the forum more and do some 'homework' ay, coz there's heaps of other mad doodz like you's who have got these on their cars, and av commented about the performance n shit, would help ya 2 not sound like such a noob ay.
With 35,000 members, there's a fair chance someone else has wondered about the same modification decisions as yourself.
Edited by GeeTR
Here's my 2c, but then dont mistake me for someone who actually knows stuff;
Split dumps are a better design and should make more power/spool better, but they are more tightly tied to turbo size (turbine diameter and wastegate diameter). If you get split dumps designed for a standard sized turbo, and try to bolt them up to a larger turbo you may have problems.
Open dumps are much less sensitive to turbo size, but wont work as efficiently.
I wouldn't worry too much about dump pipes as with a stock 33 turbo at 14 psi you'll be replacing that soon.
drop it down a couple pounds, you'll find the performance difference won't we noticeable anyway.
fwiw i have a jjr split dump/front and am quite happy with it.
Here we go...
In theory the split piping would give you more power but you would need at least 500ps-600ps atw to see the 5ps difference on the dyno. so the power difference is really small. If you were to use a bellmouth type and then drive using a split piping, you wouldnt be able to tell much of a difference. this was told to me when i was making the same decision as well.
also if you were going to upgrade your turbo in the near future to something bigger, then you would have to change to the bellmouth type anyways, only because the clearance on the wastegate with the split piping is too small.
HEYZ!
Guys im stuck between 2 setups :D
GKtech & JustJap setups, ones one piece and the other is 2 piece lol Help me D :>
pro's and cons? ect
GKtech
justjap
Edited by 32JEZ
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
