hey
i fitted a power fc and hitman has tuned it and all is well...
i am monitoring speed, knock, rpm and injectors, but when i finish a drive there is no max reading for speed or knock?
i have read paulr33's page and search the forums but have not found any info. :(
can some tell me if there is a setting that i need to set?
thanks
graham
https://www.sau.com.au/forums/topic/197076-power-fc/
There should be, unless you cleared it. Are you pushing the up button to view the max readings?
na
didnt know about the up button. :(
is thta how it is done?
was just reading what was on screen be fore turning the car off.
https://www.sau.com.au/forums/topic/197076-power-fc/#findComment-3524839
Yeah push the up button to view your max readings.
Push the right button to clear your max readings.
Push the downbutton to resume to current/live readings and keep your max readings.
Your max readings should appear surrounded by black. you'll know what i'm talking about when you see it.
Edited by KeyMaker
https://www.sau.com.au/forums/topic/197076-power-fc/#findComment-3524862
