Hey guys,
I need some help from you pros..Im planning to buy a set of rims off a S14a and want to know if its possible to fit the rims onto
my R32 Gtst..
Rims size:
Front 18x8 235/40/18s +29 offset
Rear 18x10 265/35/18s +36 offset
So what do you guys think??
Thank you in advance,
David
https://www.sau.com.au/forums/topic/197109-fitting-a-s14a-rims-size-to-a-r32/
I don't know if those rims will fit or not, but the S14 chassis can hold really wide wheels underneath its standard guards. Wheels that would stick out roughly 25mm on the S13 body will fit under the standard guards of an S14 for example.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
