Make:Nissan
Model: Cefiro
Milage: unknown
Transmission: 5 speed
Colour: Wine Red
Complied?: Yes
RWC supplied? n/a
Currently registered? NO
Price: $7000 ono
Contact:0402 266 755
Comments / Modifications:
Autech front bar and side skirts with front bar opened up for front mount.
Tein Drift Spec
R200 Diff and shafts. Aftermarket centre, no idea what
Engine has had all the seals replaced, rocker cover, cam seals etc.
Replaced aircon compressor with unit from RB25
Had alternator recoed.
timing belt replaced.
Front mount intercooler
Turbo from RB25
Chipped ECU. Power approx 170-180kw atw
Walbro Fuel pump hard wired to battery. Pulls full 12V.
Turbo back exhaust. Rear muffler replaced with twin tips muffler. Not too loud, just right.
Rims are AVS Model 6. White. 16x7 and 16x8. Front has spacer and fills guards.
Front rubber is still good 80% about 50% rears
Has Alarm with 3 point immobilizer.
Dark tints
Momo tiller.
Greddy boost guage
Really want this car gone quickly. It's been sitting in my garage for over a year now. I was meant to be fixing it up but now i can't be bothered.
it's a good car, sounds really tough and drifts really well.
It's out of rego and passed the 3 months so it will need a blue slip.
Here's some old pics. I'll take some new ones on the weekend. (doesn't come with s2 tail lights as i sold them ages ago)
Contact me via PM or by mobile on 0402 266 755.
Images:
Edited by replicate
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
