Ok so some time ago i got a new set of splitfires, which about 6 months later started to die, sent back got a full replacement. The new ones have been on for 2 months, and every now and then, i get a strange misfire, on like one cylinder, a pop for a split second and then all fine.
The car is as per sig, running 16 psi boost and BKR6EYA plugs gapped at .8 mm. I have a cam gear installed and new timming belt etc.
I was wondering if there is anything i should be checking in the car, like earthing to coils or something, surley there must be something i can do.
The missfire usually occurs in the morning, and is gone by the afternoon, and uauslly mid rpm not top rpm.
https://www.sau.com.au/forums/topic/197125-splitfires-and-odd-misfire-issues/
The misfire is random, like when you ate coming out of a corner at low TP% and open her up, it goes POP out teh exhaust and away she goes.
Usually about the 4000 rpm mark.
I have already replaced everything but computer, including injector and coil loom, AFM, TP, temp sensors, cas ect.
How are your cam cover gaskets? Is ther evidence of them leaking? Have you cleaned the coilpacks and boots? Its not happening immediately, so It could be after its built up over time :D
Are you still running that chipped ECU?
The one we've told you to get rid of or properly tuned? in all of your threads just about?
Also, what are the intake temps like?
No doubt your just making hot air @ 15psi on the stocker turbo.
Its clearly evident when you made 10rwkw with 3psi extra that your well beyond the turbo's efficiency point and running the extra 3psi is useless.
So back the boost off to a reasonable level while your there.
yes it's runing teh ecu, becuase the ecu has been checked and run on another car and it is fine, it runs fine on that car.
I tried a PFC and made no differance, the car went worse to tell you the truth, but the map was propably not the best.
As for turbo efficiency, i have no idea why but mine keeps making power, not sure what level, but i second if you stomp on it abouve 4500 rpm she will break out inot wheel spin, so clearly making decent power.
I know the turbo is past it's efficiency point, but she simply keeps going.
Inlet temps i would have to say are rather low, this is tassie and a big FMIC keeps the temps down a lot.
Every car is different...so if an ecu works fine on one car it doesn't mean it will work just as well on another...and the PFC you tried...was that tuned with your car? if not then that test tells you nothing...
Ans as for the turbo...like nismoid said...its probably past that efficiency...yes it makes decent power...but at what expense...if its a stocker you'll probably be picking the exhaust wheel out of the cat at some point...drop boost 2-3psi and get a proper tune with some sort of decent engine management...
If you've added 3psi and only attained 10rwkw, then it simply isnt 'going'.
Its clearly run out of its legs, and a sensible man would back off and keep it happy.
ok point taken running out of uff, BUT whay the misfire, anyone.
That is the main question here.
And teh turbo has been on for 16 months, at 12-14 an dnow 15 psi day in day out, and it simply will not die.
yeah new plugs disapears, but this dosen't always happen, the miss that is, but new plugs solve it for a week and then it begins to do it. BUT the missfire is VERY random.
As to ecconomy i get about, 350 or so arround town, all stop start in tassie, with VERY liberal use of teh Right Foot.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
