VG30 compressor 48mm and matching housing $60
RB25Compressor (from my car) 49mm top 62mm major slightly higher flow than the VG30 and different trim. $45
Install on your existing turbo for a lag free power gain
just need a balance-$35
matt
0413023669
82483387 a/h
https://www.sau.com.au/forums/topic/19713-rb20-turbo-upgrade-bits-cheap/
hi matt,
i have a rb20 and i have been thinking of this for a while.. so do you only replace the compressor wheel. do you need the stock housing machined. lets say that i gor the rb25 comp wheel what power increase do you think and would this be the same power as if i were to just buy a full rb25 turbo.
thanks
shaunr32
If you bought the rb25 compressor you would have to machine your housing($50) The VG30 comp and housing would totally bolt on but make 10kw or so less. You will pick up between 20kw - 50kw depending on your tuning, mods and boost. I have made 225rwkw with the RB25 compressor. Depending on the A/R exhaust housing difference between your current turbo and an RB25 turbo you could estimate lag and power differences.
Any of these wheels will make give you a large power increase.
oh im interested now . so the compressor wheels that you are selling are steel?? i know you said $50 for michining but how much for installing and fitting.?? and what would be the best one of yours for sale for the most and easiest to install on my car..
thanks much
shaunr32
