Anyone else go out to watch? Was a good day and i got to hang out with Mike coppola and learn how to use my camera and its settings alot better. Still got alot to learn but im pretty happy with some of the photos I took.
Was a few regular SAU members out on track - Luke, Richo, Nisskid, matty, Brenton
few of my pics..
Karl - Spyathe on his first time out on track
Some others
The rest
http://s113.photobucket.com/albums/n213/No...Dec%209%20Prac/
https://www.sau.com.au/forums/topic/197180-photos-from-drift-prac-dec-9/
lol well according to mike, she is still only zooming in about half wya and only using half the quality that the camera is capable of, now with those settings sorted, look out for some even better shots come January prac.
Richo - there is a decent bit of footage of you from the day, will reel a copy off for you in the next couple of days and you can grab it on saturday night.
pm sent richo.
soooooo..... its been wat, 3 days since prac and after seeing the pics and the footage, im hanging so bad again already for next prac, wanna do more tandems and puch myself bit more, richo, simon if you make it out, would love to run some tnadems with you guys. Want to follow a few guys who are higher skilled than me and try and pick up some things and just try and keep up lol.
  skylineguy19 said:
pm sent richo.
Mate, more than happy to run tandems with you, the only thing is that we need to be in the same group, for starters :devil:
I will get off my ass and get there early for a change so we can be on the same group.
lol ill bring all westys pics from sunday 2 matty could ya bring the footage from drift skool???
im alson the same cant wait 2 get out on track again! same group thing is a very high priority next parc lol other wise i wont get any tandems lol !!
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
