Axpexi Coil overs to suit R33 GTR
Good Condition:
$400 Neg
R33 GTR will need to check if it will fit to other skylines (What car)
Sydney, HORNSBY:
Via PM:
Coilovers are to suit R33 GTR and are in good condition have done about 20,000-30,000kms:
Willing to ship at buyers expense or pick up in Syndey
Edited by Geoff897
https://www.sau.com.au/forums/topic/197218-axpexi-coil-overs-to-suit-r33-gtr/
im suspecting they wont fit 33 gtst but onli the fronts or rears (cant remeber which) will bolt in :domokun: if fits up id probs buy em off u this weekend. willing to seperate if only one end fits? please let me know cheers
Here are some pictures of the coilovers and the car that they were on.
http://www.members.optusnet.com.au/jazzyge...ine/Skyline.jpg
http://www.members.optusnet.com.au/jazzyge...s/coilovers.jpg
Freight should not be a problem to SA.
I think the rears will only bolt straight up 2 a R33 gtst and the front can be modified to fit. they were on a R33 gtst when wrecked. part all other mech parts have been sold. Will not sell separately unless both front and rears sell.
