  • Replies 148
LOL, how can we add you if you cant accept the request? Let us know when you get Live up and going again.
could always go to xbox.com and manage your account from there ;) you can even send messages and change some of your profile settings.
but it doesnt matter now he is back but its there for those who didnt know.
im back on live
No your not! I had a friend request waiting for you for a couple of weeks.
Whoever hasnt played COD4 better do so now before the new Battlefield comes out. Most COD4 players will be switching to this game when its released.
Every time I go to play H3, I realise how lame it is compared to Call of Duty 4.
i second that, ill go play halo 3 with people as long as its custom games, like zombies, FFA stuff, or forging.
but im up for some cod4 just those i have on my list are not on when i am. or you are and your party is full
Look up: Kez R
I'm constantly playing COD4, seriously, my work hours are completely messed up at the moment, so I have tons of week nights to kill. Literally.
I have Forza 2 too, but I suck ass at it.
Also, for anyone interested in strategy based games look up "Catan" under arcade downloads. Cost 800 Microsoft points or something to download, but it's definitely worth it.
Look up: Kez R
i also have forza 2 and suck ass at it
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
