I tried getting rid of the plastic mount, i gave up coz i felt like i was going to break something trying to take the panel off, i unscrewed and unpluged everything i could see and it still didnt wanna come off, you get enough room to mount most speakers if you got an mdf partition, and there is still enought clearance from the grill with this partition. To make mine i just traced around the factory speakers, cut it out, drill where the factory holes are then cut my 4" into the new partition, this has plenty clearance from the grill and the plastic pod, i even sat a crossover in the bottom of the door.
Guest purple_reign
the original plastic speaker mount also has a silastic stuff holding/sealing it to the door..
i cant remember the measurement of the pioneer splits (they are a beefy speaker), but they fit well and sound good. the tweeter is on a custom pod on the inside morror panel, bit far away from the mid (might be messing with imageing) but the panel had holes in it and needed covering..
I still cant work out how to get the damn door trim off, the bastards stuck, it just wont move, so i cant put in mdf panel like you guys have, so i made a mount the same size of the factory speaker and mounted my speaker in that.
wheres it getting stuck?
have a look at the pics i attatched and follow the instructions
1 - there are 2 screws on the part that goes up against the dash
2 - then u hvae to remove the door handle surround use a little bit of force dont be scared to force it
3 - there is one in the little pocket
4 - there are 3 along the bottom
now gently pull the door trim from the bottom towards you so all the clips can pop out then lift it upwards and it should slide off
:D
  • 4 weeks later...
i agree with booster 12mm is good enough for 6.5 inch splits, you can resize the original trim to fit if you want, however just remember that splits sound different to 6x9's in the rear, i personally like 6x9's in the rear because it offers tighter bass to go from the sub.
the reason why people put splits all round there car is simply for competition, thus the cross over network sends high frequenices to the tweeter and low frequencies to the woofer enabling less distortion then 6x9's.....
however in a car that is only used for in car audio 6x9's honestly sound good when mounting them in the rear they are not that hard to do, if you want i can put them in for you (if you are on the coast and give me a slab of beers)...
and mtopx would of been better if you got them tilted at 30-45 degrees as well :D
-bryan
yeah, thanks for the help dude.. but im fine fitting and setting up the correct sound stage in the car, just doing a bit of research on the project ahead.. I would personally use coaxial's over splits, but the quality of splits these days is very good. (that would be a good dicussion point there in itself). But anyways.. thanks for the help guys..
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
    • Even though I have some pretty good (brand) ratchet ringies, I avoid using them to break open tight bolts. A broken ratchet is very annoying.
