Make: Nissan
Model: R32 GTR, 1989 model
Milage: 46,000km
Transmission: Manual
Colour: Gunmetal
Complied? Yes
RWC supplied? Yes
Currently registered? Yes
Price: $27,000 NOW $26000 ono ***NOW 25,000*** ***NOW 23,000 or nearest offer!!***
Contact: 0439762051
Item Condition: Very good condition, 46,000km on clock
Engine
Tomei Poncams in 260 ex 260
OS Gliken cam wheels
Clear cam cover
oil cooler kit
Greddy oil filter moval kit
Trust T78-33D Turbo
700cc/min Sard Injectors
Nismo Airflow meters (they are same size as factory but read like a Z32 AFM)
Full Veilside Exhaust
Nismo fuel pressure regulator
Driveline
2 way lsd rear
OS Gliken twin plate clutch
Trust intercooler with Greddy hard piping kit
Suspen & Wheels
HKS Kanzai chassis braces kit (front rear and tunnel)
Nismo castor rods
Tein struts and coils (awesome ride)
9.5 inch wide Advan RG II
Rays light weight wheel nuts (uber light!!)
Aftermaket brake pads (endless I think)
Front and rear strut braces
Interior
Personal steering wheel
Grid Dancer Dash (ATESSA controller)
HKS boost Gauge
Greddy Profec B spec II
Nismo Gear knob
320km speedo (only ever used 2/3 of it lol)
Power FC pro spec (cuts ign not fuel)
Outside
Nismo pods I thinks
Probally missed some/lots mods but hey ya get that, will add them as I remember.
Contact
Dale 0439762051
Edited by Dae Tripper
https://www.sau.com.au/forums/topic/197273-r32-gtr-480rwhp/
will get some pics for the engine bay and inside up soon.
It uses the standard gearbox with a OS Gliken Twin plate clutch. Filled with redline gear oil
It made 480hp at the wheels as stated in the title
https://www.sau.com.au/forums/topic/197273-r32-gtr-480rwhp/#findComment-3535246
  • 3 weeks later...
hey bud .. i finaly was able to pry the computer away from mi old man... id luv to hav this car but i carnt make tha sort of dollars u want + mi car if i could sell the stereo maybe i could make $5000 n mi car but still wif all mi friends no takers ...the misso keeps sayin "see if u can pay him off" but nagh its cool... but the balls in ur court if u wana work sumthing out il b down 4 that... im still tryin to find a frigen diff no1 on tha south side of brisy can get 1 4 a long time.... neways i better run got ppl to cal... il here from u later thanx bud catch ya...
https://www.sau.com.au/forums/topic/197273-r32-gtr-480rwhp/#findComment-3577550
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
