hi everyone, just a newbe question. i am looking into buy a turbo skyline but im not sure if it is going to be worth the hassle of having a turbo. i hear they need to be rebuilt every 60,000 kms costing 2grand, aren't good and overheat on long trips (which i frequently do) and if they do blow up the stuff the whole engine! are these things true? has any 1 had major issues with their turbos, or is a matter if you look after it right everyting will be good? what is a good amount of kms to buy a 2nd hand gts-t?
https://www.sau.com.au/forums/topic/197277-turbos/
Mate!! all these people telling you turbo's overheat, and blowup and arent reliable etc. dont know how to treat a car!!!
My R31 skyline was a bolt on turbo setup with nice size cooler, 10psi making 165rwkw, I tuned it backin 2003 I think and it did not miss a beat for a good 5 years untill I sold it!!!!
I drove that car in 40 degree heat with a full car load goin for cruises, to the beach etc. 40 mins drives at a time.
- it did not overheat!
- it did not blow up
- it was very relible!!
do your service every 5000k's, make sure your cooling system is working correctly and you shouldn't have any problems at all....
If you do donuts for 10 or so mins straight..... any engine will overheat!!!!
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3527539
:bunny: with friends like these who needs enemies...
Best piece of advice anyone can give you is dont rush into buying the first car you see, get it checked out and spend sometime looking at EVERYTHING for yourself. If you are in over your head then get the help from a professional (mechanic or friend) and be prepared to spend a little money doing so.
My 2cents is id rather spend $100-200 on a car to find any minor/major problems first than take a punt and having it end up costing you $$$$$$$$$
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3527579
when I bought my Skyline I knew the HKS turbo was on its way out so I got it a little cheaper.However that turbo lasted almost 2 yrs before the telltale waft of smoke while sitting at the lights.I had it fully rebuilt for just under a grand..ran beautiful...Just make sure oil changes are regular and you will have years of trouble free motoring.Dont believe all that crap that you have been told
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3527615
My 33gtst has just ticked over the 100000 (and the rest :bunny: ) and is still on the stock turbo which has had 10 pounds of hard abuse shoved down her throat for 4 years. And i still havent blown... Wait, am i still even talking bout cars here?
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3527675
My R34 GTT has:
Done the trip from Brisbane to Sydney in a day. No issues. Just spent a minute longer cooling down the engine before switching it off.
Plenty of >3hour trips.
Does 2 >1hour trips on a daily basis. Hasn't missed a beat.
Use decent oils and regular maintenance and these cars will out last most cars on the road.
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3527847
Skyline's aren't a cheap car to run by any means.. Maintenance, insurance and running costs are all higher than normal every day cars. If cheap motoring is what you're after look elsewhere. Having said that, Skyline's will be reliable if you look after them as said previously.
The stuff that you've posted is an absolute load of crap. Maybe that sort of stuff is true if you are using your car for drags / track / drift events twice a week, lol.
Over-heating on long trips lol..
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3527928
One thing people haven't mentioned here is that boost levels can effect the lifespan of the turbo. Standard ceramic wheeled GTR turbos (non R34 N1) shouldn't be boosted above 15psi or 1 Bar (although there are plenty of people who have and haven't had any problems... yet). I don't know about GTS-T turbos but I imagine they have a common boost break point as well.
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3528647
i agree with this wholly. skylines are made to cop a belting and will ask for more. you just have to keep high maintenance.
make sure you keep everything under/at it's limits and the car with run fine under most if not all conditions and situations..
eg: if you've got a stock fuel system and bolt on a huge turbo without a tune, you will come across problems eventually. you have to mod everything in consideration. if you go for a long drive you should make sure your turbo cools down before switching the car off. this site is a huge resource for that sort of stuff!
as DRD-00F said, GTS-t's are safe at 12psi. make sure you have an aftermarket boost guage to monitor this.
hope that helps! :D
Edited by dmr
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3528773
My 33gtst has just ticked over the 100000 (and the rest :( ) and is still on the stock turbo which has had 10 pounds of hard abuse shoved down her throat for 4 years. And i still havent blown... Wait, am i still even talking bout cars here?
hahaha... hamish u crack me up!
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3529025
I see what's happened here..
Your mates have obviously confused the word TURBO with the word ROTARY.
I beg to Differ.
My old Series 3 Rx7 had 230,000ks on the original motor....never missed a beat.
Even drove it from Melb to the Gold Coast In December and Ran beatifully :)
Look after any car and you wont have any worries with it.
Preventative mantinence. Making sure nothing can go wrong is a lot easier than fixing somthing when it does.
https://www.sau.com.au/forums/topic/197277-turbos/#findComment-3543681
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
