Hi all,
When i get my car back next month i will be pulling the turbo off and will be sold,along with braided oil and water lines.
I purchased an 0P6 housing and had it matched with my turbo.Then it was highflowed at Precision Turbos.
Highflow consists of machined front and rear housings(maximum)
Garrett Ball bearing cartridge.(will try and find the serial number for the cartridge)
It also comes with braided oil and water lines.
It has only been on the car for roughly 7000kms and is basically brand new.
I made 250.9rwkw at 16psi with this turbo.Has alot more in it and wouldnt be suprised if it would make 270-280 with a bit more boost.
The rear housing cost me $350
Braided lines $200
Highflowing of turbo $1550
Im asking $1650+post firm.
Old turbo off new turbo on.... big power!
NOW WITH FREE SILICONE INLET PIPE(second hand in excellent condition)
Bass Junky type.
Contact by PM.
CHEERS
https://www.sau.com.au/forums/topic/197284-highflowed-rb25vg30-bb-turbo/
  • 1 month later...
OK everyone i have finally got my car back so the turbo will be coming off the car.Those who sent me PMs for the turbo please get in contact with me before it goes to someone else.
dyno chart?
comes with reciepts/warranty?
direct bolt on for r33 gtst s1?
reason for selling?
Doesnt come with a warranty.But the thing is in great condition,i wouldnt be selling it if it wasnt.
Reason for selling is i have another turbo waiting to go in.And it will bolt on no probs comes with braided lines as described in first post.
is the just a standard r33 highflow? fitted it yet?
Sure is mate. Would have loved to buy NYTSKY's turbo its a very well spec'd hiflow but mine was too much of a good deal to pass up.
Its getting tuned today, I'll post up the results tonight after I've taken it for a drive.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
