044 - ~$230 delivered from many places. CRD on here are one em of em.
600hp, though are externals so no one way check valve. You'll also need a couple of fittings.
An 040 should do 400rwhp easy though; wouldn't touch a walbro with my enemies c_ck.
  • Replies 41
ok so here is an update
I spoke to another mechanic and got my plugs gapped he asked me to bring in the car so he can inspect it.
That night i put them in and it ran fine uped the boost to 15psi little miss here and there otherwise seemd fine except there was no real power till around 6000rpm? arounf about an hour or 2 later i herd a weird sucking sound like boost leak or air block checked all the hoses and pipes best i could cant find a leak anywhere its only under load the sound comes and it wont let me get more then 10psi took it into the shop next day and they had it all day.
Well he said its not the fuel pump its running 40 psi? and its not stock so thats not the issue
he tried a differnt air flow senser thats not it they took the ehaust off to check for block cat thats not it they tried a new computer but that wouldent even start it
they also dynoed it its getting 104 or 114 at the wheels i cant rember and the reason it pulls at 6000 rpm is becuse the power flat lines at 5000 then picks up again at 6000 they spent the whole day on it and cant work out the issue there asking for it back tommorow hopefully they will work it out.
Im kinda getting over it.im thinking about just scrapping that motor and saveing up and getting a rb26 as i think the end result we be that its had it does any one know if the rb26 will bolt up to my standard gear box?
and if a rb26 head +rb30 bottom end is a good idea thinking about that option 2 i herd good and bad things just wondering what you guys think
