Hi,
I'm a new a new member here.
Cool, me too.
My R33 is a 97model. GTR-T. Shiny white. Mmm shiny. So grats on the car! Lots of fun!
Recently got myself some 2nd hand back tires from Northwest in Fyshwick. Im DARN poor after Autotech stuffed up an inspection on my car. Bought the darn thing only to have problems. Oh well. Still, tires seem pretty good and was charged $150ea.
Sooooo need money hahaha :blink:
He meant GTS-T.
I think "doh" fits in here rather well.
As with the 2nd hand tires... Northwest went over the tires with me. Still had all the tread and what-not. Havnt had any problems so-far and the guys seemed pretty honost.
Plus I know some other people who buy from them. They never had a problem with their 2nd hand tires.
As they say, "time will tell". :D
Im not saying that the guys at Northwest tyres are dodgy or anything.
Im saying that tyres can be destroyed by users even without showing signs of wear, if the person who bought and used the tyres before you did a burnout on them when they were brand new then the compound will be no good as doing that sort of thing kills the tread compound.
Also the tyres could have defects in the carcass such as spread or broken cords which wont show up unless the tyre is fitted and inflated and sometimes wont show up straight away, it can take a few km's before you see a buldge in the tread or sidewall.
Also the tyres may have been used under inflated which stresses the cords and sidewall construction inside the carcass causing premature wear and internal damage, sometimes if the tyre has had this happen for even a couple of hundred km's it may weaken the casing meaning that there is an increased chance of puncture.
Good luck with them though, I honestly hope that you got a good set :D
Edited by Bullet32
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
