Hi guys, my car has no receiver dryer and no ac fan, and constantly pumps unstoppable hot air through the vents. I'm really not mechanically minded so could someone explain to me wtf is going on and how i can get it fixed cause i have no idea where to start.
have u checked that the switch for where the air comes from is not set onto outside air..U know the switch where u can change it from outside air to recirculating air already inside the cabin..
if u have it to outside air no matter if the a/c is off air will still come thru
vinnie is right, turn it on, and press recirculate so that the green (?) light comes on. let it change over to recirculate and turn it off. then never touch it again lol
yeah tried that, does nothing.
If the interior air sensor is disconnected you will only get hot air so my guess is that it will be either faulty or disconnected. If you find its connected try running the climate control diagnostic to see if its faulty. Common thing to find with your symptoms. The sensor is located on the center console facia behind where there is a small vent in it. Pull it off and you will see what i mean. If you need pics, i can arrange them.
Deren
i have same problem but i have aircon. I cant get it to recirculating. Would it be either the switch or the motor that powers the flap? If so, how hard is it to get to the motor?
Thanks
Sounds like one of your motors are dead. Either the motor which controls the hot/cold air or the face/feet/etc direction motor or both!
Try the diagnostic first to see what it tells you. The motors are located behind the dash and it requires you to take everything out to replace them.
Hi.
What Deren is referring to is the sensor which is behind the 4 slits located beside the ash tray. To check the sensor is connected remove the ash tray look and you will see the sensor on the right hand side. Locate the wires coming from it and if it is not connected fish around and find the other connector- you cannot go wrong as all the connectors only fit one thing. Hopefully this should fix the problem. If you have any work done to your car recently ie clutch or new stereo equipment it is usually the cause as professinals?? who do the work like to remove the surround which goes around the centre dash equipment and neglect to connect this or the cigarette lighter wires. Hope this helps.
There is another sensor located in the engine compartment on the firewall behind the engine although is not normally a problem unless you have been playing around in that area.
man, this thread has reminded me how hot R32 GT-Rs are when the weather is warm.
even with the vent set to recirc, the heat that comes through the firewall and floorpan when you drive it for a while is annoying
you could always try the simplest solution and see if all the vacuum lines are connected at the back of the climate control panel - don't laugh, I had the exact symptoms you described - checked everything they pulled the stero out again and found i'd knocked the lines off. 5 minute job and problem solved. i had added a new head unit.
My 32 GTR was the same - constantly blowing hot air, even with it set to recirculation... this thread helped me fix mine - http://www.skylinesaustralia.com/forums/R3...old-t93814.html :D
R32's dont use vacuum to control vents etc. Its all electronic with motors doing the work. Sounds like its actually quite easy to see the connecter as our12 described. Check that out. Good chance its the cause. If not its a good place to start anyway. Process of elimination.
Deren
behind the stereo surround/console theres a plastic line it hink its for the climate control.
i left mine off by accident once and it kept blowing hot air in, connected it back up and air was normal :P
yes there is the intake temp hose behind the dash just to the right of the air con panel,if that falls off or if you have pulled the dash out it blows just hot air
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
    • Won't get near 400kw, pump and injectors nowhere big enough. Bin the manifold and get off the shelf and a modern ECU.
