Item: R32 Fog Lights
Condition: Excellent
Price: $30
Contact: Steve
For Sale are the Fog Lights from my R32 GTS-T. These are in good working order. They were removed as they could not fit in anymore after the Front Mount Intercooler install.
Edited by Hydroxinol
https://www.sau.com.au/forums/topic/197368-r32-fog-lights/
hey dude, what front bar did you have them fitted to? gts, type M etc?
any pics of it on the car? i wanna see if it will fit in my front bar atm.
cheers
PM sent.
https://www.sau.com.au/forums/topic/197368-r32-fog-lights/#findComment-3556313
do these work very well? as in lighting up the road
i would like pics of them on the car too.
Yea, they are bloody awesome. I had them hooked up to my low beams and would get the occassional flash....oops :blink:
Will send pics in a PM
https://www.sau.com.au/forums/topic/197368-r32-fog-lights/#findComment-3558217
Replied to both enquiries via PM.
Due to the high frequency of picture requests I will provide them for everyone. To answer questions about fitting the Fog Lights, my Front Bar is plastic and of a different colour to the rest of the car (I bought the car with this already on). So I do not know for certain if it is factory standard. Hopefully the pics can help you out.
Regards,
Steve.
https://www.sau.com.au/forums/topic/197368-r32-fog-lights/#findComment-3581445
  • 2 years later...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
