Set of 4 R34 GT-T stock wheels 5X114.5 with brand new tyres on them only used to compliance shop and back
asking 500 0400565607 ( No Offers Please as ive spend more then 500 on tyres)
will post pics up in the weekend
pic of wheels attached to Car Original off a 00 model S2 34 GT-T
Tyres are 225/45/17 with 98% tread on all 4
Offset are +40 will fit all skylines 31 32 33 34 comes with all nuts as well
SOLD
Edited by 53XYN
https://www.sau.com.au/forums/topic/197370-r34-gt-t-wheels-brand-new-tyres/
what are the wheel and tyre sizes I need new tyres, I bought some V35 rims but they came with 50 profiles which scrub, do you have side on pic i forget what they look like.
Edited by SevenAngryPenguins
hey bud the tyre size on them are pretty sure 225/45R17 i will get you pics tonite or tomm morning as they are all stacked up in the shed .. b4 i sell them all 4 tyres will get balanced as well come with all nuts if required
Edited by 53XYN
Pics are up bummmmmmmmmmmp
All 4 wheels have been balanced by Jax Quickfit Slacks creek
Edited by 53XYN
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
