Hi guys,
i found this one one of the discount websites im registered with and thought some of you guys may like in on this deal
me and Bunny33 have gone halves in a set, there are 29 sets left mine is being AAE posted i will post up picks when i get it :(
Details
Our Price : $139.95
Average Retail : $189.00
YOU SAVE : 26%
Features:
* Massive 7 km range
* 1 Watt transmit power
* 40 Licence free channels
* 38 Privacy codes (CTCSS)
* Range extender in duplex mode
* Channel scan
* Keypad lock
* Keypad tones
* Backlit display
* Battery level indicator
* Low battery alert (audible)
* Roger beep
* Channel busy indicator
* Time-out timer
* Call tones
* Accessories: 1 twin desktop charger, 2 rechargeable batteries, 1 AC adaptor, 2 replaceable coloured faceplates
* 2 bonus microphones
Specifications:
* Two-Way Radio Dimensions: (H) 17cm x (W) 6cm x (D) 3cm
* Brand: Motorola
* Model: T5509R
>>Product Link<<
https://www.sau.com.au/forums/topic/197395-walkie-talkies/
Details
Our Price : $139.95
YOU SAVE : 26%
Features:
* Channel scan
* Keypad lock
* Keypad tones
* Backlit display
* Roger beep
* Time-out timer
* Call tones
>>Product Link<<
Hi Steve, I don't want to take anything away from the quality of these units but a 1 watt radio wont give you 7km range in Adelaide you'll need a 5 watt in perfect condictions to come close. We use radios regularly on the road and find that the way they are rated is at night in the country with no buildings or trees around.
Having said that, if you need something for communication between 2 cars driving together, 1 watt is definitley the way to go because it won't chew up battery life and won't get too hot.
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3529473
i was going to get a pair of the Uniden ones for $50 but i thought even that was expensive for something i might only use once a month...This looks like a great unit and deal though for sum1 who decent quality...
Maybe we should organize a group buy for some :banana:
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3529507
Steve I want a set tell me whats needed for you to obtain these for me.
if you want put $155 in my account and i will order today will get here on monday if you do ring me and let me know so i can put order in ASAP 0421932750
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3530190
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
