hey guys
just wondering if i can run my car with no boost controller with my hks adjustable actuator?
my hiflow should be getting fixed soon and i dont want the hassle of getting caught with a boost controller.
i have heard that u can but being an internal gated turbo how much boost spike do you tend to get. or boost creep? (on my r33gtst)
much appreciated.
i did a search but couldnt find the answer i was looking for
thanks
You should be right running of an upgraded actuator, you'll only see the boost that the actuator is set too however.
It might taper off a little in the top end where a EBC might help hold boost
It might also build boost a little slower
But that are only a might, its not a certainty to occur, you might be totally fine :banana:
I have done this on other turbo engines with adjustable actuator, but not a skyline, basically the tightness (or preload) on the actuator will determine your max boost, the only big problem is if the line blows off the inlet pipe the actuator will keep the wastegut shut and you can overboost.
From experience...while these adjustable actuators do give some boost control...you still want a proper boost controller to hold the wastegate shut till you reach the desired level of boost...if not you'll have the wastegate creeping open as you build boost...set up properly a proper boost controller will give better response and also more midrange...
im running boost of the actuator..
on 16psi spikes to around 17-18 then drops..
when it was on 18psi spiked to 20psi :S
also feels a little laggy, can i get an ebc or do i have to get a stock r33actuator for the hks 2535?
Boost controller is definately way to go, just remember though your lowest boost setting will always be dependant on how the actuator is set, so you could loosen off your actuator to the 7psi mark, then with the boost controller you can set your high mark at whatever you want.
Would have to reccommend the gizmo IBC as it is simple to use, has 4 settings, with gain control and controls the boost really well. definately improve your lag factor
With the HKS adjustable actuators i think the lowest you can go is around 14psi...from there you can use a boost controller to raise the boost...remember...you want to keep the wastegate shut while you build boost to the required level before it opens...thats where the response and surge of midrange comes from...
At 18psi peak boost for example a car will make the same power but if you hold the wastegate shut till max boost you build boost quicker and hence fatten up the midrange...its all about area under the curve...
ok so set the hks actuator to as low as possible then get a ebc (dont have cash for profec b right now, ill search gizzmo) and set that to say 17-18ish..
would i need to get a retune?
You do not necessarily need to set the HKS actuator to as low as possible...i would use it to help control the spiking...if your boost is spiking too much then it would help to lengthen the actuator arm slightly...and if boost response is slow...then i would shorten the arm slightly as it probably shows its opening too soon...its a finicky process but once set about right then you're ready to use a boost controller of some sort to raise the boost...that way you'll get better boost control...
On a side note...i run the same turbo (HKS2535 on my rb20 and t makes about 220rwkw)...your peak power is definitely higher but i noticed that your power starts to climb alittle slower than mine even though mine's an rb20...not saying that anythings wrong but it might be worth looking into...something might be holding it back perhaps...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
