hey guys the car im getting from melb has a turbo timer and alarm. Now turbo timers are illegal and i want it removed b4 i buy the car. So what im asking is how much would it be for a workshop to remove the Turbo timer and if the turbo timer is intergrated into the alarm how much would it be then?
oh and also price for removing the alarm coz im getting a better one?
Cheers
*Vinnie*
https://www.sau.com.au/forums/topic/197461-turbo-timer-uninstallation/
Turbo timer... when mine was going through compliance I just disconnected one plug + 1 ground wire and removed the unit. Easy.
Have the electrician remove the previous alarm when you have the new one install at the same time... usually works out cheaper.
Should be well under $100 to remove the turbo timer (it is a 30 minute job at worst). Or do it yourself and leave the wiring in there.
Agree - get the installer of your new alarm to remove the old one - while the car is in 1000 pieces is the cheapest and easiest way to remove the old, then reinstall a new alarm
for regency i just unplugged it from teh loom. and then hid the cables up near the steering column underneath the plastic (as mine was located near the steering column). At worst, just do this and leave the loom in. Then you can plug it in whenever you want.
I moved mine to the glovebox along with my boost controller so they werent obvious in the even i get pulled over.
cheers for the advice guys
yeh i wanna removie the turbo timer tho
i dont want to have one as it exposes the ignition wires n what not
i asked the guy im getting it from to ask his workshop how mucht heyd do it for and he sed $65\
is that too much or not?
cheers
cheers
Dude seriously........ Exposing the ingition wires doesn't matter..... If they want it they don't care about plastic, they smash it!!
Also there will be other things on the car that will get you defected anyways, But hey its your car and if you don't want it on there then i'm not gonna stop you!!
I've heard of more stupider things done with turbo timer so yeh.............
ahh k well then maybs i keeps it lol
i just want it to get registered
how do u get to put your car thru the cop shop on Sturt Rd as ive herd they only look for tin, lowering and obvious shit. so if im remove jst the unit it should be oka?
Yeh there was a thread about buying cars from interstate and getting them rego'd here and going thru Sturt!! I'm not sure exactly what times or days they are open but someone here will be able to tell you!!
Yeah Wed & Thur you can go to Sturt without an appointment for a Vin & Engine No inspection only if it's an interstate car.
Yup
+1
between 9am - 3am 2yrs ago, not sure about it now.
I thought it was tues and thursday only, but I cant remember, wed + thur is probably is !
rock up, wait, have all paperwork, and make the car look as stock as possible inside the engine bay / dash / outside body
