Can anyone tell me where to start, i want to do the work myself and wanted to know wear various drain plugs and alike are (Diff mainly). Also any tips or things to be careful about would be much appreciated, i do not have a hoist at my disposal.
Cheers
Mate use the search function, youd be amazed at how it helps.
this will help with oils to use, how much etc etc
http://www.skylinesaustralia.com/forums/Di...Oil-t11443.html]
and this is generally how to change them but this is on a gts-t gearbox
http://www.skylinesaustralia.com/forums/R32-Changing-Gearbox-Oil-t30665.html
http://www.skylinesaustralia.com/forums/Ge...hange-t631.html
and the diff i couldnt find too much, however its almost identical to gearbox bar the oil u use and how much. Filler hole should be somewhere around the top of the diff, and the drain plug somewhere near the bottom (gravity works well to drain the oil) haha. This is ONLY for the rear diff however. Im unsure on the front diff on yours as i do not own a gtr nor have changed the front diff oil in one. But i couldnt imagine it being too much different to the rear.
Hope this helps
Edited by R32Abuser
as well search the general maintenance thread for the FAQ has all the amounts etc for the GTR i believe. Usee what iv told u as a guide tho. Good luck with everything, its not too hard but just always when draining the oil to undo the FILLER hole before u undo any DRAIN hole.
