***BMW 318is SEX SPEC-ER***
179XXXKM's - Auto - VGC
WILL ALSO GIVE A *FIND-ERS FEE* FOR ANY MEMBER WHO CAN SELL THIS CAR. $200.
Contact Details
Mob ; 0434341473
Email / Msn ; [email protected]
Hey guys,
Just wanting to sell the daily drive around - it currently has NSW rego but can be easily rego'd in Victoria. Has passed RWC - and will provide RWC on buyers request.
MODS;
Custom exhaust system so that was all changed by Bros Exhaust ( all receipts can be provided )
8000K HID Systems
Euro Tail Lights
Euro Front Lights
Angel Eyes
Suspension Mods
New bilstein struts up front
Boge on rear
King spring All Round
Wheels;
E46 m3 wheels 9" front 9.5" rear, new falken ziex 235/40 all round
*HANDLES LIKE A DREAMMMMM!!!
INTERIOR;
At the moment it has stock interior but custom interior is coming on the 19th of December.
Everything else is stock - just changed all light bulbs and checked.
*Will sell with the interior.
AUDIO;
This is where the car will shine ..
Headunit;
Pioneer IN DASH DVD Player 7" Touchscreen
Speakers;
Front
6" Front's
3" Mids
Tweeters
Rear
6" Rears
2 x 12" Subs in custom box
600W Pioneer 5 Channel AMP *Powering 2 front spilts, and 2 rears.
400W Pioneer 2 Channel AMP *Powering 2 12" Subs.
All amp wires are SONY amp wires.
Each amp are powered and ground by there own places.
Exterior;
Custom Black Pearl Paint.
18" Wheels - OEM BMW.
Body is straight
No body damage
***PRICE; $13,000 ONO***
*First to see will buy*
Edited by shook
Still up for grabs
[ if deposit doesn't fall through ]
Price is negotiable!!! *Just need money to start my new project*
OFFER STILL STANDS IF ANY MEMBER CAN SELL THIS CAR TO ANOTHER PERSON WILL RECEIVE A REWARD.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
