Hi Guys,
I recently purchased an R33 GTS-T and I am having some troubles with the power.
When I run 10 PSI, it seems to go quicker compared to when I run 12 PSI, why is this? It's killin me!
I got the following Mods:
GReddy Front Mount intercooler
3 inch exhaust (from the turbo back)
Pod filter with Cold air intake
Splitfire coil packs
Turbosmart manual boost controller
It almost feels as though the car doesn't want to pull on 12 PSI, the power feels so flat...
I get crazy wheel spin when I shift to 2nd gear running 10PSi, but when I run 12 PSI, I would be lucky to get a little squeek outta the tyres.
I thought it might be a faulty boost controller or that I may have to re gap my spark plugs to 0.8..
Has anyone had simular problems or know what the problem may be?
Cheers
  • Replies 51
To some degree ... but using a piggyback style/ signal bender messes with the factory ecu's knock correction functions ... which is bad news if you get a dodgy batch of fuel and a really hot day those things are a recipe for disaster.
Best thing to do in your situation is to leave the thing on 10psi (because much more than this will markedly shorten the standard turbos service life ... 12psi is getting to the pointy end of what is considered safe with a standard turbo) and save for either a full replacement computer or a rechip/ flash of the standard ecu.
A reflash or rechiping of the factory ecu is the ideal solution for most lightly modified 33's for a few reasons.
1. It's relatively cheap (around $1000 or so)
2. It's technically a leagal mod (all aftermarket ecu's are considered a defect)
3. It retains the factory ecu engine protection functions, cold start, and partial throttle/ cruise/ economy settings.
The only real downside to all of this is that adding extra mods and tuning is generally not as easy as just tweaking the maps, it generally requires a little bit more than this and finding someone around your area to do this can sometimes be hard.
The next mods after this you should look at are a new fuel pump, high flow turbo, and a bigger set of injectors and quite possibly a Z32 AFM ... with these mods and 16~18psi you should quite comfortably see 240~250rwkw's and ear to ear smiles when you plant that right foot towards the floor :P
My 2 cents hope this helps. :)
ohh by the way what you are experiencing is called boost cut or fuel cut ... your factory ecu has a function that robs you of power when it detects an amount of air flow that is outside what it considers normal ... the only to get rid of this annoyance is to (a) lower boost until it goes away or; (b) install a piggyback, replacement ecu or reflash the standard ecu.
I thought a fuel cut is when the car jerks you forward suddenly(ie. shuts the fuel off so the car temporarilty stops if over boosted)?
Basically, on 12 PSI, it feels as though I am driving with the handbrake half up. Feels like I am running 6 PSI. :P
I am sure you can imagine what it would feel like to drive your car with the handbrake semi up, yep, like sh!t......
It think this has been covered already in the thread, but a re-chipped/aftermarket ecu would be a safe and good mod for your situation, re-gapping the plugs will not solve your problem. GL with it man, use the advice mentioned above.,
hame
safc will be fine with minor mods its just a bit of a compromise to a stand alone ecu because you cant adjust the timing so you might have to run a little richer up top do a search you will find shitloads of info on safc's
Edited by SevenAngryPenguins
Upgrade your fuel pump, i had to do the same, now that i have changed turbo to GTRS i have same problem and today i am upgrading pump again
boost/fuel cut kicks in around the 14.2psi and you will know if you hit it, i used the apexi safc and have been for around 4yrs running around the 13psi mark, granted that my turbo did eventually let go, but only after countless races, circuit days and drift days,
Using the safc will also remove factory boost cut, so make sure you have it checked on a dyno that you are not leaning off
So basically, what you are saying is that the Apexi NEO (Piggy back system) is pretty much useless (due to the inherent risk of detination), and that I would need a power FC or some other aftermarket ECU?
^^ pretty much they are more of a band aid than anything else
Its because you're running less backpressure and hence giving you more power ... the more psi you boost it up to means more turbo lag... I wouldn't say you go faster - more so less lag... if that makes sense.
*shakes head* you sir are an idiot
okay im gonna drop the boost down in my cars now cause it will "run less backpressure and give me more power"
Edited by R34GTFOUR
-sigh- dude this has been covered to death. it is the stock ecu. it has a process of RICH AND RETARD. when u go over 10psi the ecu freaks out and retards the timing and dumps fuel....hence the rich.
this results in the car feeling as tho it is hitting the wall, and is slightly jerky with a huge flat spot. twist it back to 10PSI.
safc will help with the rich problem. but it doesnt monitor or control timing etc.
GET A REAL EAM ECU.
greddy emanage ultimate controls timing.
em blue is fine but lacks the features of the emu
Edited by r33cruiser
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
