FINALLY THANKYOU MAN FOR A RESPONSE.
im going after 600hp. and if i get more. its a bonus.
DONT worry about internals (springs, pistons, sleeves, rods, solid lifters,crank, valve stems/guides./fuel supply (squirters, pump/s), electrics etc.
im just wondering what size turbo would get me there that comes on boost below 4000rpm if possible.
if possible, a snail that gives me breathing room to go further if i ever want to..
but for now 600-700hp snail is what im after.
i was thinking a US-spec super t70
Edited by r33cruiser
  • Replies 51
you have a few opinions
HKS T51R SPL
HKS T51R KAI
HKS T04Z
Blitz K5 or K6
Trust T88, T78, td06
etc etc....
i would look at a hks or garrett T04Z, size it up to how much power you want so you can select the correct rear housing size, not sure if you will be full boost under 4000rpm :happy: check out this topic : http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
its got alot of information of different types of turbos on rb25, also cams will affect lag etc...
Edited by [Michael]
how come ive heard of skylines running 12 psi with only a cooler and exhaust?
The stock turbo is fully capable of making 12 psi, infact likely much more then that [ ive accidently hit over 15 on mine :) ] . However the life of the turbo is much reduced when running levels of boost higher then it was ever designed for.
IE you can do it, you prob just wont be able to do it for very long.
without some form of modification to the standard solenoid or some other form of boost controler, im not sure how just an exhaust and cooler would cause 12 psi?
taking the stock ceramic/nylon wheeled turbo past 10-12pound is inefficient.
the ceramic wheel was built for response not power.
it will simply not be efficient at these levels.
it doesnt have the mass to sustain the boost levels past 12pound
Its because you're running less backpressure and hence giving you more power ... the more psi you boost it up to means more turbo lag... I wouldn't say you go faster - more so less lag... if that makes sense.
arent we in the forced induction section? or is this the v8 section??
ahaha so stupid...
WOW my topic is still open!!! WOOT WOOOOOO!
Anyway, I purchased myself a Power FC, brand new one from ebay for $1,540 with 1 year warranty and invoice, not bad considering second hand ones still sell on ebay for $1,300!
I haven't gottent around to installing it yet, however, I am sure it'll fix my problems!
I also got an a brand new Apexi NEO that I am selling if anyone is interested ($320)
I want to upgrade my fuel pump, does anyone have any suggestions as to what I can get, and how much itll cost me including installation, fiurthermore, will I see an Increse in power from it?
CHeers ladz
don't know anything about safc but if it works for GTT R34...ill take it for $250 :D
Dude, they are selling on ebay for $400 without postage cost.
ANd yes it will work for you R34. In addition, I also got a genuine apexi stand for it which I will throw in for free.
here ya go mate... depending on your power needs the bosche 040 is perfect for your needs and can sustain 400hp.... from memory it is about 200-300 bucks...
it has a filter in it...so its a direct replacement. just put it in the harness...then slide it in.
Yer bosch 040 are a good little pump.. although you could get the new walbro pump that is still intank but flows as much as an external bosch 044.. about 600hp from memory... haha although this would be overkill for you, so 040 IMO
I would reccomend the bosch over the walbro, i had the walbro and it shit itself in less than a year, also had a mate that had one and it died too.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
