Originally posted by rob77
it makes the car run rich or you pop and fart on every gear change :D
heh... *sarcasm off*
i have a HKS SEQ BOV and when i shift gears the exhaust makes a loud poping noise :) i kinda like it, It gives the car character. (oh and its awersome when u make a huge poping noise when the SS Ute u just killed off the line is behind you ;))
Guest Boxhead
i like the idea of the GFB stealth fx hybrid..
it appears that you can easily change the rate of hyrid style it is, as in you can direct it all via plumb back, or all of it to the atmosphere....
or a rate in between, so it could be good, fair enough if a cop knows what he is talking about he will spot the trumpet if you dont conceal it.. but, if you are going through a cop hot spot you can pull over turn it to totall plumb back and not get the original attention
I had a Turbosmart Supersonic Type 3. It was good, no complaints at all. Bit loud though so I returned to my stock plumbback and the car drives heaps better.
Just doesn't get wheelspin on the 3rd gear change anymore, just a little chirp now if I try hard enough.. So to those people that say they are not a performance part must be wrong. It obviously gave my car more boost after gear changes.
Still got the BOV if anybody wants it.
Originally posted by rev210
Areograce,
Never said fmic's were not a performance mod. But, you keep telling people thats what I think cause from now on I follow your advice.
what?:confused: follow my what advice?
i'm just saying in your instance, a cooler upgrade isn't needed to run fast 1/4mile times....sorry if i sounded sarcastic:cheers:
I read about this company that spent milions on research and development on their Products.
the bovs that they make can handle up to 17psi without any probs, and you can also make a slight mod to the bov to hold more boost.
the company is called NISSAN.
the bovs can be picked up second hand for like $30.
you can't go wrong..
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
